LHY AUDIO LPS25VA Linear Regulated Power Supply 15V 1A
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 15V.
Reference : 19037
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 22-04-2025.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 15V 1A 25VA
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 15V 1.5A 25VA : Front view
This power supply includes a Talema transformer coupled with an AOP 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation and two DC 5.5/2.1mm jack output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
Input voltage220-240V
Output Voltage / current15V 1.5A Max
15V 1A Continuous
Outputs2x Jack DC 5.5/2.1mm
InputIEC
Case materialAluminium alloy
Dimensions110 x 155 x 63mm
Weight1.114kg
Package1x LHY AUDIO LPS25VA
1x DC 5.5/2.1mm male/male jack cable 80cm
1x power supply cable
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)15.0
Output current (A)1.0
Input voltage (V)220.0
Power SupplyRegulated Linear Power Supply
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
