LHY AUDIO LPS50VA Linear Regulated Power Supply 12V 1.5A
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 12V.
Reference : 19043
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 22-04-2025.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 12V 1.5A 50VA
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 12V 3.5A 50VA : Front view
This LHY AUDIO LPS50VA regulated linear power supply ensures high stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this dedicated audio power supply, and it will pair perfectly with your 12V HiFi equipment.
This power supply includes a custom OFC copper-wound transformer coupled with an AOP 177 for more accurate voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 9uV.
The power supply benefits from an aluminum alloy case for efficient heat dissipation and a GX16 aviation output. There's also a switch for disabling grounding to avoid ground noise. Finally, you can adjust the output voltage on the back of the unit by ±0.5V if required.
Please use the GX16 cable supplied or the GX16 Audiophonics cable for LHY power supplies (sold separately, see accessories). Please also check the polarity of the two pins.
Input voltage230V
Output Voltage / current12V 3.5A Max
12V 1.5A Continuous
Outputs1x Plane GX16
InputIEC
Case materialAluminium alloy
Dimensions110 x 155 x 63mm
Weight1.114kg
Package1x LHY AUDIO LPS50VA
1x Plane GX16 to DC 5.5/2.1mm male jack cable 80cm
1x power supply cable
InputIEC C14
OutputGX16
Output voltage (V)12.0
Output current (A)3.5
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
