LHY AUDIO LPS50VA Linear Regulated Power Supply 15V 1.5A
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 15V.
Reference : 19045
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 16-04-2025.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 3A 50VA : Front view
This LHY AUDIO LPS50VA regulated linear power supply ensures high stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this dedicated audio power supply, and it will pair perfectly with your 15V HiFi equipment.
This power supply includes a custom OFC copper-wound transformer coupled with an AOP 177 for more accurate voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 9uV.
The power supply benefits from an aluminum alloy case for efficient heat dissipation and a GX16 aviation output. There's also a switch for disabling grounding to avoid ground noise. Finally, you can adjust the output voltage on the back of the unit by ±0.5V if required.
Please use the GX16 cable supplied or the GX16 Audiophonics cable for LHY power supplies (sold separately, see accessories). Please also check the polarity of the two pins.
Input voltage230V
Output Voltage / current15V 3A Max
15V 1.5A Continuous
Outputs1x Plane GX16
InputIEC
Case materialAluminium alloy
Dimensions110 x 155 x 63mm
Weight1.114kg
Package1x LHY AUDIO LPS50VA
1x Plane GX16 to DC 5.5/2.1mm male jack cable 80cm
1x power supply cable
InputIEC C14
OutputGX16
Output voltage (V)15.0
Output current (A)1.5
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
2 reviews
Super Produit
Alimente un Zen Ifi Streamer. parfait
This review has been posted for LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA
Stupéfiant!
A peine branché sur mon Ifi Zen Stream et là je redécouvre un son chaleureux, clair et détaillé avec des basses percutantes. Les instruments et les voix se détachent les uns des autres avec une clarté incroyable. On peut monter le son, ça n'est jamais désagréable. J'avais acheté le streamer d'occasion et l'adaptateur livré était un vulgaire adaptateur ac-dc 12v 1a... autant dire qu'avec cette alim linéaire 15v3A sur le streamer, tout mon système hifi se retrouve mis en valeur... aucune hésitation à avoir à ce prix, le streamer et son alim c'est le top du top!
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
