LHY AUDIO LPS80VA PREMIUM Linear Regulated Power Supply 12V 2.5A
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 12V.
By buying this product you get 32 loyalty points
Reference : 19049
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 01-04-2025.
LHY AUDIO LPS80VA PREMIUM Linear Regulated Low Noise Power Supply 230V to 12V 2.5A 80VA
LHY AUDIO LPS80VA PREMIUM Linear Regulated Low Noise Power Supply 230V to 12V 5A 80VA : Front view
This LHY AUDIO LPS80VA regulated linear power supply ensures high stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this dedicated audio power supply, and it will pair perfectly with your 12V HiFi equipment.
This power supply includes a BLOCK Toroidal transformer coupled with a TL431 OPA for furthermore precise voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a MOS tube ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 20uV.
The power supply benefits from an aluminum alloy case for efficient heat dissipation and two GX16 aviation outputs. Finally, you can adjust the output voltage on the back of the unit by ±0.5V if required.
Please use the GX16 cable supplied. Please also check the polarity of the two pins.
Input voltage230V
Output Voltage / current12V 5A Max
12V 2.5A Continuous
Outputs2x Plane GX16
InputIEC
Case materialAluminium alloy
Dimensions130 x 250 x 60mm
Weight2.190kg
Package1x LHY AUDIO LPS50VA
1x Plane GX16 to DC 5.5/2.1mm male jack cable 80cm
1x power supply cable
InputIEC C14
OutputGX16
Output voltage (V)12.0
Output current (A)2.5
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
