Cette alimentation stabilisée et régulée repond parfaitement à mes attentes.
Low noise USB 5V 2A 25VA / 230V
This linear regulated power supply is ideal for your creations / repairs / improvements systèles audiophiles. It is a solution of choice for powering your audio properly functioning elements with a voltage of 5V and enjoy excellent stability to encourage the performance of sensitive equipment.
The circuit features a regulator Hexfet IRF-controlled by an operational amplifier 5534A Texas Instrument low noise. Thus, the control stage works in class A, which severely limits the heating circuit compared to one based on the LDO architecture.
Power receives the input of 230V (AC) and offers three separate outputs. There are two USB ports, one capable of delivering up to 24W power will ideally dedicated to the charge / power energy devices or particularly long to load. The latter is essentially meeting the fast charging standards as found on current smartphones. The second USB por, always on the front is a classic powered port, but enjoying all the benefits of a stable and accurate feeding.
"The benefits of a linear power quality are improved readability high-midrange and a better Cut bass. So this linear regulated power solution developed by our team competes more expensive solutions.
Equipped with a 100% aluminum casing, an output DC Jack 5.5 / 2.1mm, 2 USB outputs, this power supply with a transformer 25VA extremely stable even under heavy load will allow you to make the best of the connected audio components. "
Type | linear regulated power supply |
Inputs | AC 230V (Port IEC C14) |
Outputs | DC female Jack 5.5 / 2.1mm USB A female (fast charge) USB A female |
Transformer | 25VA armored, shock |
Case material | 100% Brushed Aluminum sandblasted |
Weight | 1kg |
Dimensions | 150 x 120 x 55mm |
Package contents | |
linear regulated power supply | x1 |
DC cable jack 5.5 / 2.1mm to DC jack 5.5 / 2.1mm | x1 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
