QULOOS QP2 Dual Regulated Linear Power Supply 12V 5A Silver
The QP02 power supply made by Quloos is a powerful linear regulated power supply (LPS) designed with high-end components. This power supply features two DC 12V 5A outputs, making it possible to power two devices simultaneously. The power supply of your Hi-Fi system is an important factor in obtaining a clean, stable signal, as the electrical signal is the basis of any sound impulse.
By buying this product you get 59 loyalty points
Reference : 17858
599,00 €tax incl.
499,17 € tax excl.
QULOOS QP02
A powerful power supply
The QP02 power supply uses an 80W toroidal transformer, 6A Schottky rectifier diodes and voltage regulators with an output current of 5A for each DC output. In its design, Quloos has therefore allowed for a certain margin regarding the power of its power supply system, so that you can fully use the Hi-Fi system it will be powering. This allows your Hi-Fi system to be used at high volume, while maintaining a wide, detailed sound field. This means your system will deliver a fuller and more stable sound.
High-end components
As the power supply of any Hi-Fi system has an impact on sound quality, Quloos has chosen high-end components for its QP02 power supply. These include an Schurter IEC socket with fuse, a Nuvoten Talema toroidal transformer, a Philips electrolytic capacitor, a Siemens non-inductive film capacitor, a Vishay MKP1837 capacitor and a Wima MKP10 capacitor.
Each DC output uses an LT1084 supply voltage regulator chip, linear, low noise and high current capability. An LT1084 regulator can deliver 5A continuous current, and features 0.015% line regulation and 0.01% load regulation.
Accessories for immediate set-up
Thanks to its two DC outputs, the QP02 can power two devices simultaneously. It comes with a high-end 0.5m Quloos DC-1X cable and a conventional 1.5m DC power cable.
It is recommended not to use the QP02 in overlap with other devices, as it is very sensitive to shock absorption.
QP02 rear panel
1Power switch
2Input 250V Fuse
3IEC C14
4Ground terminal
5DC1 12V output
6DC2 12V output
Product typeDual regulated linear power supply
Input voltageAC 100-120V 50/60Hz
AC 220-240V 50/60Hz
(Selection switch available on the underside of the case: 230V or 115V)
Output voltage / currentDC1 + DC2 : 12V (5A max. cumulative)
DC1 or DC2 : 12V 4A
InputIEC C14
Outputs2x Jack DC 5.5/2.1mm
Power80 VA max.
Dimensions197 x 197 x 55 mm
ColorSilver
Net weight2.3 Kg
Gross weight3 Kg
Package1x Quloos QP02 regulated linear power supply
1x Schuko power supply cable
1x DC cable DC-1X Quloos
1x DC cable 18AWG 300V Fenda
1x User manual
InputIEC C14
OutputJack DC 5.5/2.1mm
ColorSilver
Output voltage (V)12.0
Output current (A)5.0
Input voltage (V)115.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
The QP02 power supply made by Quloos is a powerful linear regulated power supply...
