SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 15V 2.5A / 16V 1.85A / 16.5V 1.65A
With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply. The two-stage mains filter and ground choke eliminate high-frequency electrical pollution before the current reaches the transformer. The audio-grade transformer is custom-built and electrostatically and magnetically shielded.
By buying this product you get 34 loyalty points
Reference : 17936
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 25-04-2025.
SBooster BOTW P&P ECO MKII Alimentation Linéaire Régulée 15V 2.5A / 16V 1.85A / 16.5V 1.65A
The electronic design of this power supply is innovative: it uses 50% more energy from the components used, and even consumes up to 35% less energy than a conventional design. The BOTW P&P ECO MKII concept is so efficient that it consumes only slightly more energy than a standard adapter, generating more electrical pollution. So your energy bill is only slightly affected by the BOTW P&P ECO MKII.
At the end of the DC jack cable is a unique current-splitting system. The BOTW P&P ECO MKII power supply provides this system with continuous, clean power, so that the electronics can do their job efficiently: first storing the power for greater power supply responsiveness, then filtering the voltage and current one last time before they reach the audio device.
This unique power supply, with its high power reserve, delivers a pure and sufficient electrical signal to the audio device it powers at all times, ensuring stable and continuous performance.
Each model of the BOTW P&P ECO MKII, thanks to its intelligent design, features three output voltage settings. What's more, all models feature an interchangeable, self-locking DC jack connector system. This makes the BOTW P&P ECO MKII an extremely versatile power supply, capable of accompanying a wide range of HiFi equipment.
Key features:
  • 50% more output current.
  • Power saving design.
  • Substantial power for equipment requiring high currents.
  • High precision for the most noise-sensitive equipment.
  • 3 switchable output voltages.
  • Standard input connector in IEC C14 format.
  • High-performance two-stage mains filter.
  • Earth line choke.
  • Overvoltage protection.
  • High-efficiency, audio quality custom transformer.
  • High-quality polypropylene film capacitors.
  • No noise SBooster split current system.
  • High quality PCB. 2oz. double-sided copper. Gold plating.
  • Efficient heat sink.
  • Internal wiring in silver-plated copper with PTFE insulation.
  • Transformer with high-frequency electrostatic and magnetic shielding.
  • Low ESR capacitors.
  • Jacketed and shielded DC output cable.
  • Custom gold-plated DC jack connectors.
1IEC C14 power input
2Fuse
3Polypropylene film capacitor
4Common-mode choke
5Earth line choke
6Overvoltage protector MOV
7Silver plated wiring with PTFE insulation
8Mains voltage selection switch
9Audio grade toroidal transformer
10Non-inductive polypropylene capacitor
11Low ESR/ESL bulk capacitor
12Low drop linear regulator
13DC output setting switch
14Schottky rectifier
15DC cable: Positive/Negative/Shielding
16Braided cable
17Split-current system
18Female DC connector
Product typeRegulated linear power supply
Input voltage200-240VAC 50/60Hz
Voltage / Current output (switchable)15V 2.5A
16V 1.85A
16.5V 1.65A
Transformer50VA
Mains filterHigh-performance two-stage filter with earth choke
RectifiersPower Schottky barrier rectifiers
CapacitorsLow impedance, high ripple current capacitors
RegulatorsHigh-current, ultra-fast transient response LDO with high-precision external shunt reference circuit
Filtering capacitorsNon-inductive polypropylene film capacitors
Jack DC cable length95cm
Jack DC cable section1.309mm² (16AWG)
Cable shielding
Current-splitting system on DC cable
Interchangeable Jack DC connectors
Jack DC connectors platingGold
Dimensions240*130*75mm
Weight1.85kg
Package1* SBooster BOTW P&P ECO MKII
1* Power cable
Jack DC connectors (various formats)
InputIEC C14
OutputJack DC
Output voltage (V)15.0
Output voltage (V)16.5
Output voltage (V)16.0
Output current (A)2.5
Input voltage (V)240.0
Input voltage (V)200.0
Power SupplyRegulated Linear Power Supply
With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted...
