By buying this product you get 27 loyalty points
Ultra-Low Noise Linear Power Supply 15V 1A 2x5V 2A Black
The Soncoz LP1 is an ultra-low noise linear power supply that provides your audio system with the clean, stable electrical signal required for quality sound reproduction. The power supply features a custom sealed toroidal transformer, combined with a separate rectifier and regulator module with three rectified outputs. This independent design greatly reduces the interference between the outputs and consequently reduces the noise floor. The regulation stage uses five TPS7A4700 ultra-low noise linear voltage regulators. Each 5V output is connected in parallel to two chips and the maximum output current is up to 2A.
The LP1 power supply has three independent outputs. The first one delivers 12/15V 1A on a DC jack connector, while the two others, on USB-A ports, provide 5V 2A. Each output can be activated or deactivated via the buttons on the front of the device.
To this, the LP1 adds intelligent and practical functions, such as a memory of the states (ON/OFF) of each output when the power supply is turned off, a luminous indication in case of overload, a verification of the integrity of the system each time it is turned on, or a timer function that allows the power supply to be turned off automatically after 2 or 3 hours.
All of the Soncoz LP1 power supply's components are concealed under a sturdy CNC-machined anodized aluminum chassis in a sleek, minimalist design.
If both 5V outputs are active, then they provide 2A for one and 1A for the other, or 1.5A each.
1 | 12/15V Output LED Indicator |
2 | #1 5V Output LED Indicator |
3 | #2 5V Output LED Indicator |
4 | Status LED Indicator |
5 | 12/15V Output ON/OFF switch |
6 | #1 5V Output ON/OFF switch |
7 | #2 5V Output ON/OFF switch |
8 | Settings switch |
9 | Power switch |
10 | Fuse |
11 | Input power connector |
12 | Input voltage selector |
13 | #2 USB-A 5V output |
14 | #1 USB-A 5V output |
15 | Jack DC 12/15V output |
Product type | Linear power supply |
Input voltage | 110/220VAC (switchable) |
Output voltages | 1x 12/15VDC 1A via Jack DC 5.5/2.5mm 2x 5VDC 2A via USB-A |
Consumption | < 45W |
Output noise floor | < 20µVrms |
Dimensions | 149.9 x 87 x 74mm |
Weight | 1300g |
Color | Black |
Package | 1x Soncoz LP1 1x Power cable 1x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm adapter |
Input | IEC C14 |
Output | USB |
Output | Jack DC 5.5/2.5mm |
Color | Black |
Output voltage (V) | 5.0 |
Output voltage (V) | 15.0 |
Output current (A) | 1.5 |
Output current (A) | 1.0 |
Output current (A) | 2.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 220.0 |
Power Supply | Linear |
