SONCOZ LP1 Ultra-Low Noise Linear Power Supply 15V 1A 2x5V 2A Silver
The Soncoz LP1 is an ultra-low noise linear power supply that provides your audio system with the clean, stable electrical signal required for quality sound reproduction.
By buying this product you get 27 loyalty points
Reference : 16150
279,00 €tax incl.
232,50 € tax excl.
Soncoz LP1
Soncoz LP1 Alimentation Linéaire Ultra-Faible Bruit 15V 1A 2x5V 2A
The Soncoz LP1 is an ultra-low noise linear power supply that provides your audio system with the clean, stable electrical signal required for quality sound reproduction. The power supply features a custom sealed toroidal transformer, combined with a separate rectifier and regulator module with three rectified outputs. This independent design greatly reduces the interference between the outputs and consequently reduces the noise floor. The regulation stage uses five TPS7A4700 ultra-low noise linear voltage regulators. Each 5V output is connected in parallel to two chips and the maximum output current is up to 2A.
The LP1 power supply has three independent outputs. The first one delivers 12/15V 1A on a DC jack connector, while the two others, on USB-A ports, provide 5V 2A. Each output can be activated or deactivated via the buttons on the front of the device.
To this, the LP1 adds intelligent and practical functions, such as a memory of the states (ON/OFF) of each output when the power supply is turned off, a luminous indication in case of overload, a verification of the integrity of the system each time it is turned on, or a timer function that allows the power supply to be turned off automatically after 2 or 3 hours.
All of the Soncoz LP1 power supply's components are concealed under a sturdy CNC-machined anodized aluminum chassis in a sleek, minimalist design.
If both 5V outputs are active, then they provide 2A for one and 1A for the other, or 1.5A each.
112/15V Output LED Indicator
2#1 5V Output LED Indicator
3#2 5V Output LED Indicator
4Status LED Indicator
512/15V Output ON/OFF switch
6#1 5V Output ON/OFF switch
7#2 5V Output ON/OFF switch
8Settings switch
9Power switch
10Fuse
11Input power connector
12Input voltage selector
13#2 USB-A 5V output
14#1 USB-A 5V output
15Jack DC 12/15V output
Technical characteristics
Product typeLinear power supply
Input voltage110/220VAC (switchable)
Output voltages1x 12/15VDC 1A via Jack DC 5.5/2.5mm
2x 5VDC 2A via USB-A
Consumption< 45W
Output noise floor< 20µVrms
Dimensions149.9 x 87 x 74mm
Weight1300g
ColorSilver
Package1x Soncoz LP1
1x Power cable
1x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm adapter
InputIEC C14
OutputUSB
OutputJack DC 5.5/2.5mm
ColorSilver
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)1.5
Output current (A)1.0
Output current (A)2.0
Input voltage (V)110.0
Input voltage (V)220.0
Power SupplyLinear
The Soncoz LP1 is an ultra-low noise linear power supply that provides your audio system with the clean, stable electrical signal required for...
