Switched Mode Power Supply 100-240V AC to 32V 10A DC
This AC adapter takes an input voltage of 100-240VAC to output 32VDC 10A. The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices.
Reference : 14750
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 22-04-2025.
Adaptateur Secteur Alimentation
100-240V AC vers 32V 10A DC
This AC adapter takes an input voltage of 100-240VAC to output 32VDC 10A. The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices. The circuit also integrates protections against overcurrents, overvoltages, thermal overshoot and short circuits. The AC input is on an IEC C14 connector and the output on a GX16 connector.
Product typeSwitched mode power supply
Input1x IEC C14
Output1x GX16
Input voltage100-240VAC 50/60Hz
Output voltage32VDC 10A
Voltage precision±5%
Package1x 32V Switched mode power supply
1x Power cable
1x GX16 to Jack DC 5.5/2.5mm (5.5/2.1mm compatible) cable
Dimensions102 x 208 x 50mm
Housing materialBrushed aluminium
Silver front panel
InputIEC C14
OutputGX16
ColorSilver
Output voltage (V)32.0
Output current (A)10.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)100.0
Input voltage (V)130.0
Input voltage (V)230.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)110.0
Input voltage (V)120.0
Power SupplySMPS
Makes a difference
Used a cheap 24v 10 a laptop power supply (which is better than the stock 32v 5a power supply) with my Fosi Audio TB10D, wanted something better and a little bigger (more power) so this it was, since 48v might be able to make my amp play louder but also alot hotter, i didn't want to go all in.
More clean sound, less grainy highs,cleaner midrange,tighter better controlled bass, fast delivery, no pop sound turning m,y amp on,off
I wish it could be had with a black front
This review has been posted for Switched Mode Power Supply 100-240V AC to 32V 10A DC
This AC adapter takes an input voltage of 100-240VAC to output 32VDC 10A. The components are integrated in a robust aluminum chassis that...
