TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Black
This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the latter. Particularly practical, the P50 has 2 USB-A outputs of 5V 1A and 1 DC 5.5/2.1mm jack output of 15V 1A. It is therefore possible to supply several devices with a single power supply.
Reference : 14032
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-04-2025.
Topping P50
Topping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1A
Topping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1ATopping P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1A
Effective associations
The P50 can be associated with a wide range of devices, with output voltages of 15V and 5V being very common for HiFi devices. The power supply is of course an ideal choice to power the brand's other products, such as the DX3 Pro, the D50s, or the D50s and the A50 at the same time.
Switchable input voltage
The power supply is compatible with the input voltages AC220-240V 50/60Hz but also AC100-120V 50/60Hz and can therefore be used anywhere in the world. A 230V/115V switch is used to select the input voltage.
Be sure to select the input voltage corresponding to the voltage supplied by your electrical system before connecting it to your power outlet.
Sealed toroidal transformer
The P50 uses a high quality, custom sealed toroidal transformer, ensuring low magnetic losses and a very low noise level. In addition, the transformer has been designed to eliminate noise and residual interference, in order to provide the cleanest possible signal.
Large energy reserve
The 15V power supply circuit integrates a series of capacitors for a total capacity of not less than 10000µF and the 5V rails have 8000µF. A significant energy reserve to ensure stable output signals.
Ultra low noise linear regulators
The P50 uses 3 ultra-low noise linear controllers TPS7A4700. These chips are capable of high accuracy and therefore perfectly suited for HiFi use and make them an excellent choice for analog circuits.
Aluminium case
All the components of this P50 power supply are integrated in a beautiful and robust Aluminium housing. It is CNC machined in a single piece of metal for better mechanical performance and reduced interference.
Dimensions
Package content
Product typeRegulated linear power supply
Input voltageAC110V/AC220V, 50Hz/60Hz
Input connectorIEC C14
Output voltages2x 5VDC 1A
15VDC 1A
Output connector2x USB-A
1x Jack DC 5.5/2.1mm
Noise< 1mVrms
Dimensions11 x 11 x 5.2cm
Weight0.88kg
Case materialCNC machined Aluminium
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)15.0
Output voltage (V)5.0
Output current (A)1.0
Input voltage (V)115.0
Power SupplyRegulated Linear Power Supply
2 reviews
Excellent
Excellent produit. M'a permis d'alimenter un 'vieux' dac nuprime udsd grâce au câble audiophonics usba mâle vers 2x USB femelle et en même temps y connecter un iphone ou un dap qui ne pouvaient alimenter le dac. J'ai l'impression que le son du DAC s'en trouve amélioré.
This review has been posted for TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Black
A worthwhile and affordable upgrade
I’ve been using Raspberry Pi and various HAT combinations for a few years around the house, in the bathroom, bedroom, garage etc. Powered from a selection of switching mode power supplies. No complaints, they sound fine. But for my “main” system I persuaded myself that I needed to upgrade. I am glad I did. I have removed all the switching mode power supplies from nearby and I am running an Audiophonics iSabre DAC and a Pro-Ject Phono DS2 Ultra from this Topping device. The improvement is tangible. The sound emerges from a quiet background and it has atmosphere and presence. Particularly enjoying the recent release of Bill Evans at Hilversum. I recommend this inexpensive upgrade. (Other components are - iconAudio 40i Stereo Valve Amplifier, ATC SMC11 loudspeakers, picoreplayer, Logitech média server.)
This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the...
