Ultracapacitor Power Supply Filter Module 5-24V DC
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors.
4.8 / 5
Reference : 18915
42,90 €tax incl.
35,75 € tax excl.
Ultracapacitor Power Supply Filter Module5-24V DC
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors. This power filter reduces potential interference and noise from your power system. This power filter is ideal for powering a Rapsberry PI, digital interface, NAS, router and more. The module features gold-plated DC5.5/2.1mm input and output connectors, as well as screw terminals with copper contacts for simplified connection when required.
Product typeSupply filter module
Inputs1x DC 5.5/2.1mm jack
1x Screw terminal block
Outputs1x DC 5.5/2.1mm jack
UltracapacitorsWIMA
Operating voltage5-24V DC
Maximum rated current10A
Package1x Ultra-capacitor filter power supply module
Dimensions16 x 5.2 x 2.2cm
Mounting holes spacing14.8 x 4.4cm
InputScrew terminals
InputJack DC 5.5/2.1mm
OutputScrew terminals
OutputJack DC 5.5/2.1mm
ColorN/A
Output voltage (V)24.0
Output voltage (V)5.0
Output current (A)10.0
Input voltage (V)5.0
Input voltage (V)24.0
Power SupplyNC
6 reviews
Excellent produit
Petit avis rapide.
Ce produit respire la qualité de fabrication.
Après quelques jours d'utilisation, j'obtiens un son plus plein avec des détails supplémentaires . Ce n'est pas le jour et la nuit mais une fois que vous le retirez, il y a bien une différence . Il est donc resté ! Merci encore à audiophonics pour sa rapidité et la qualité de ses emballage .
This review has been posted for Ultracapacitor Power Supply Filter Module 5-24V DC
I didnt expected this quality for this price! Didnt used it yet, but just by holding in hand everything looks great. No cold solder points, connections are straight.
Ottimo risultato
Consigliatissimi.
Usati su alimentatore lineare IAN canada linearpi mk II con uscita a 12 volt per alimentare dac RME adi 2, dac RME adi 2 pro be fe. Per alimentare in 5 volt tramite ian canada linearpi mk II scheda audio usb da pc.
Per alimentare router e switch tramite alimentaotri lineari con lt3045, per alimentae nas con alimentatore lineare da 15 ampere con 5mV di ripple massimo ed ogni volta che sono stati inseriti è migliorata la resa.
Tolti e messi dal Ian canada linerpi mk II han fatto la differenza, anche il altre situazioni.
Portano l'mpianto ad una maggiore risoluzione.
Consigliati anche nel nas, router, switch! Per assurdo posizionati anhe solo li migliorano sia l'audio che il video del pc!
A cheap way to improve your PSU
I use this module in combination with a "Power supply module Dual DC LM317 T 12V 1.5A (Ref. 8424)"as an external PSU for an USB-Card. After installing the Ultracapacitor Module we could hear more details and the musicians were better to localise. Very nice!
I don´t give this module 5 stars because I tested the IAN CANADA UCCONDITIONER and it is even better. But it is more expensive too. So the Ultracapacitor Module really is quite a good choice if You don´t want to spent the money for the IAN CANADA module.
Kwalteitsprodukt!
Aangesloten op mijn transportpi van ian canada.. meer details nu te horen en betere plaatsing. Printplaat ziet er degelijk uit! Aanbevolen!
This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating...
