By buying this product you get 74 loyalty points
Audio Bastion's X-Rack HiFi stand series is one of the brand's top-of-the-range products. They represent the perfect blend of design, quality and functionality. Each model uses robust, durable materials. The structure is made of 304 stainless steel and hand-polished alloy, ensuring great solidity and a perfect black finish. The rear of the racks is completely uncluttered for easy cable management. The lower part of each unit is equipped with adjustable spikes for perfect levelling of the structure. What's more, each level of the frame uses internal spikes, increasing vibration damping and thus reducing possible resonance in the listening room. So, with X-Rack furniture, you can enhance your audio system both aesthetically and practically, while promoting its performance through effective vibration damping.
The Audio Bastion DX-3S has three stages and dimensions of 38.8 x 29.8 x 38cm. The bottom tier can support a load of 15kg, and the upper tiers 10kg. Each level is equipped with movable feet to adapt to your various devices.
Product type | HiFi stand |
Materials | Stainless steel Alloy Silicon |
Number of levels | 3 |
Levels dimensions | 300 x 280mm |
Max load per level | Bottom level: 15kg Upper levels: 10kg |
Total dimensions | 388 x 298 x 380mm |
Color | Black |
