AUDIO BASTION DX-3L HiFi Stand
Audio Bastion's X-Rack HiFi stand series is one of the brand's top-of-the-range products. They represent the perfect blend of design, quality and functionality. Each model uses robust, durable materials
By buying this product you get 94 loyalty points
Reference : 19209
949,00 €tax incl.
790,83 € tax excl.
Audio Bastion DX-3L Meuble HiFi 3-Tier Stainless Steel HiFi Stand 508x388x380mm Black
Audio Bastion DX-3L: HiFi stand
Audio Bastion's X-Rack HiFi stand series is one of the brand's top-of-the-range products. They represent the perfect blend of design, quality and functionality. Each model uses robust, durable materials. The structure is made of 304 stainless steel and hand-polished alloy, ensuring great solidity and a perfect black finish. The rear of the racks is completely uncluttered for easy cable management. The lower part of each unit is equipped with adjustable spikes for perfect levelling of the structure. What's more, each level of the frame uses internal spikes, increasing vibration damping and thus reducing possible resonance in the listening room. So, with X-Rack furniture, you can enhance your audio system both aesthetically and practically, while promoting its performance through effective vibration damping.
The Audio Bastion DX-3L has three stages and dimensions of 50.8 x 38.8 x 38cm. The bottom tier can support a load of 15kg, and the upper tiers 10kg. Each level is equipped with movable feet to adapt to your various devices.
Audio Bastion DX-3L: Anti-vibration system Audio Bastion DX-3L: Composition Audio Bastion DX-3L: Dimensions
Product typeHiFi stand
MaterialsStainless steel
Alloy
Silicon
Number of levels3
Levels dimensions440 x 370mm
Max load per levelBottom level: 15kg
Upper levels: 10kg
Total dimensions508 x 388 x 380mm
MaterialAcier inoxydable
MaterialSilicon
MaterialMetal
AUDIO BASTION DX-3L 3-Tier Stainless Steel HiFi Stand 508x388x380mm Black
Audio Bastion's X-Rack HiFi stand series is one of the brand's top-of-the-range products. They represent the perfect blend of design,...
