AUDIO BASTION XR-1 Stand for Power Amplifier 650x570x200mm 80kg
The Audio Bastion XR-1 is a high quality stand mainly intended to accommodate power amplifiers. It allows you to effectively dampen, thanks to the use of spikes in particular, the vibrations of your device in order to reduce the frequencies that could generate resonances in your listening room and alter the reproduction of your sound system.
By buying this product you get 90 loyalty points
Reference : 17393
900,00 €tax incl.
750,00 € tax excl.
Shipping date: 24-04-2025.
Audio Bastion XR-1
Audio Bastion XR-1 Support pour Amplificateur de Puissance 650x570x200mm 80kg
The Audio Bastion XR-1 is a high quality stand mainly intended to accommodate power amplifiers. It allows you to effectively dampen, thanks to the use of spikes in particular, the vibrations of your device in order to reduce the frequencies that could generate resonances in your listening room and alter the reproduction of your sound system. It thus favors a clear reproduction, with a beautiful depth and sound stage for an optimal listening experience. The XR-1 also benefits from a very nice design quality with a frame mainly made of 304 stainless steel.
Product typeAmplifier stand
Dimensions650*570*200mm
Max. load80kg
MaterialsStainless steel 304
Silicon
Net weight14,5kg
Diameter (mm)N/A
MaterialAcier inoxydable
MaterialSilicon
Height200.0
The Audio Bastion XR-1 is a high quality stand mainly intended to accommodate power amplifiers. It allows you to effectively dampen, thanks to the...
