BURSON AUDIO MOTHERSHIP 01 Aluminum HiFi Stand
BURSON AUDIO MOTHERSHIP 01 Support HiFi Aluminium
The Mothership 01 from Burson Audio is an aesthetic and functional 2 stages HiFi rack. This audio rack will allow you to install your HiFi equipment. The support pillar hides cables for an aesthetically pleasing appearance.
By buying this product you get 42 loyalty points
Reference : 18198
429,00 €tax incl.
357,50 € tax excl.
Aluminum HiFi stand
The Mothership 01 from Burson Audio is an aesthetic and functional HiFi rack. This audio rack will allow you to install your HiFi equipment. This rack is made of high-density extruded aluminum and is CNC machined. It optimizes air circulation around your HiFi equipment. The support pillar hides cables for an aesthetically pleasing appearance. The Mothership 01 has 2 stages, making it perfect for coupling devices such as a DAC with an amplifier. This HiFi/Rack audio stand is compatible with a wide range of Burson Audio products.
Product typeHiFi stand / Audio rack
MaterialAluminum
Number of level2
Load capacity5kg/stage
Cable management system
CompatibilityBurson Audio Conductor 3X Reference
Burson Audio Conductor 3X Performance
Burson Audio Funk
Burson Audio Playmate 2
Burson Audio Conductor 3 Performance
Burson Audio Composer 3X Performance
Burson Audio Soloist 3X Performance
Burson Audio Soloist 3X Grand Tourer
Burson Audio Conductor 3X Grand Tourer
Total dimensions400 x 260 x 250mm
Gross Weight5kg
ColorSilver
Package1x Burson Audio Mothership 01 HiFi stand
ColorSilver
MaterialAluminium
The Mothership 01 from Burson Audio is an aesthetic and functional 2 stages HiFi rack. This audio rack will allow you to install...
