PANGEA VULCAN PREMIER SE MKII Vinyl Turntable Wall Mounted Shelf 18kg
The Pangea Vulcan Premier SE MKII wall-mounted turntable shelf can support loads of up to 18kg. This top-of-the-range shelf greatly attenuates vibrations that could harm the performance of your audio system, thanks to its monoblock steel U-frame and a non-resonant MDF piece lined with a metal adjusting tip.
Reference : 19900
199,00 €tax incl.
165,83 € tax excl.
Pangea Vulcan Premier SE MKII Vinyl Turntable Wall Mounted Shelf 18kg
Photo of Pangea Vulcan Premier SE MKII wall mounted shelf
The Pangea Vulcan Premier SE MKII wall-mounted turntable shelf can support loads of up to 18kg. This top-of-the-range shelf greatly attenuates vibrations that could harm the performance of your audio system, thanks to its monoblock steel U-frame and a non-resonant MDF piece lined with a metal adjusting tip. The whole assembly decouples your turntable from any environment that might cause vibration or resonance. In addition to these major advantages, the Pangea Vulcan Premier SE MKII shelf saves considerable space in your Hi-Fi installation, whether on your cabinet or on the floor. In addition, a space between the shelf and the rear mounting plate facilitates the installation and positioning of cables.
Advantages of the Pangea Vulcan Premier SE MKII wall-mounted shelf:
  • Up to 18kg load (20lbs)
  • Acts as a high-performance decoupling system
  • Space-saving and easy to assemble
  • 2.5cm space for cable management (1")
  • Strong cantilever construction
  • Non-resonant MDF shelf top with durable black vinyl finish
  • Height-adjustable metal spikes for shelf leveling
  • Includes all mounting hardware
To ensure stability and resonance control, the backplate and frame must be mounted on wall studs, masonry, brick/concrete, thick wood panels or other solid wall surfaces.
Mounting hardware and an illustrated installation guide are included.
Photo of Pangea Vulcan Premier SE MKII wall shelf with vinyl turntable
Product typeWall-mounted turntable shelf
Load capacity18kg (40lbs)
DimensionsShelf: 450(W) x 380(D) x 19(H)mm
Fixing plate: 450(W) x 200(H)mm
Weight7.25kg (16.5lbs)
Package1x Pangea Vulcan Premier SE MKII wall mounting shelf
1x Mounting set
MaterialMDF
The Pangea Vulcan Premier SE MKII wall-mounted turntable shelf can support loads of up to 18kg. This top-of-the-range shelf greatly attenuates...
