Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Black
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high resistance to oxidation and corrosion.
Reference : 13437
4,50 €tax incl.
3,75 € tax excl.
Shipping date: 26-11-2024.
Wiring cable
Copper / Silver 4mm² PTFE Sleeve Ø 3.6mm Black
Fil de câblage Cuivre / Argent 4mm² Gaine PTFE Ø 3.6mm Noir
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high resistance to oxidation and corrosion. The conductor is covered with a PTFE insulating sheath to limit interference and therefore noise.
Product typeWiring cable
Conductor materialOFC Copper
Conductor platingSilver
Conductor section4mm²
Conductor composition49 x 0.32mm
Cable diameter3.6mm
Insulating sheath materialPTFE
Operating temperature-65°C / 200°C
ConditioningSold per meter
Diameter (mm)3.6
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.0810
Ground / ShieldingNo
2 reviews
Câble hp cuivre argent
J utilise ce câble pour alimenter un hp grave avec succès. Bonne tenue des basses
This review has been posted for Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Black
Intelligent design.
This cable has an intelligent design. It is made of medium strands that are twined tightly. It is almost like a single core with the added benefits of a greater surface area and flexibility. With the silverplating, large diameter and good dielectric, it's a very good conductor for high level audio signals. Top marks.
 (4)
This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while...
