LAPP KABEL Olflex HEAT Triple flexible conductor Silicone 1mm² Red
Reference : 13053
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 04-02-2025.
triple conductor cable ÖLFLEX
Cables LAPP KABEL Ölflex are recognized for their excellent heat resistance. This model can indeed withstand temperatures of -50 ° C to + 180 ° C.
An effective insulation leurpermet silicone remain much more flexible than traditional PVC cables for easy installation problems and establishment in environments where space is limited
This type of cable contains no halogens.
Characteristics
Typestranded wire ÖLFLEX HEAT 180
Number of cores3
Nominal voltage300/500 V
InsulatingSilicone
Conductor Area CSA1 mm²
max150°C
min-50°C
Tension test2000 V
Outside diameter7 mm
Weight / meter79 g
Diameter (mm)7.0
Number of conductors3
Insulation materialSilicon
ShieldingNo
Section (mm²)1.00
Conductors material (Cable)N/A
Ground / ShieldingNo
