Medium-high frequency motor, 80W MAX, 8 Ω.
High-performance, high-performance, professional-grade, high-performance, professional-quality, professional speaker with 12 "and 10" woofer. Replacement SP-30PAX / VC is available as an option, the acoustic values are given for a combination with the MRH-200 horn.
Specifications Speakers | |
Impedance (Z) | 8 Ω |
Resonance frequency (fs) | 800 Hz |
Maximum bandwidth | fx-19000 Hz |
Crowds. cutoff (fmax.) (12dB / oct.) | 1800 Hz |
Maximum power | 180 WMAX |
Nominal power (P) | 80 WRMS |
Pressure sound. (1W / 1m) | 109 dB |
Angle dispersion (green / sun) | according to flag |
Coil diameter | 44.4 mm |
Magnet diameter | 130mm |
cutting | according to flag |
Mounting depth | according to flag |
dimensions | Ø 134 mm x 58 mm |
Weight | 2.75 kg |
Speaker Power (W RMS) | 80.0 |
Speaker Type | Horn loudspeaker |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 25.0 |
