Motor with horn, 100 W MAX, 8 Ω
With standard 35 mm (1 3/8 ") threads, good linearity of the frequency band and high sound pressure for low distortion: a motor suitable for all types of professional applications, combined with a bass-midrange speaker 38 cm (15 ") or in multi-channel systems. The acoustic values mentioned result from the combination of this loudspeaker with the MRH-120. Replacement mobile reel available as optional MRD-120 / VC.
Specifications Speakers | |
Impedance (Z) | 8 Ω |
Resonance frequency (fs) | 1300 Hz |
Maximum bandwidth | fx-17500 Hz |
Crowds. cutoff (fmax.) (12dB / oct.) | 3000 Hz |
Maximum power | 100 WMAX |
Nominal power (P) | 50 WRMS |
Pressure sound. (1W / 1m) | 107 dB |
Angle dispersion (green / sun) | 40 ° / 90 ° |
Coil diameter | 34.5 mm |
Magnet diameter | 120 mm |
cutting | according to flag |
Mounting depth | according to flag |
dimensions | Ø 120 mm x 85 mm |
Weight | 1.8kg |
Speaker Type |
Impedance (Ω) |
Loudspeaker diameter (mm) |
Diaphragm type |
Efficiency / Sensitivity (dB) |
Max Linear Excursion (Xmax) (mm) |
Speaker Power (W RMS) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
