MONACOR MRD-160 60W Horn Speaker Driver High Midrange 60W 8 Ohm 109dB Ø2.5cm
Reference : 1518
85,00 €tax incl.
70,83 € tax excl.
Medium-high frequency motor, 150 W MAX, 8 Ω.
High-performance, high-performance, professional-grade, high-performance, professional-quality, professional speaker with 12 "and 10" woofer. Replacement SP-30PAX / VC is available as an option, the acoustic values are given for a combination with the MRH-200 horn.
Impedance (Z) 8 Ω
Resonance frequency (fs) 750 Hz
Maximum bandwidth fx-18000 Hz
Crowds. cutoff (fmax.) (12dB / oct.) 2000 Hz
Maximum power 150 WMAX
Nominal power (P) 60 WRMS
Pressure sound. (1W / 1m) 109 dB
Angle dispersion (green / sun) according to flag
Coil diameter 44.4 mm
Magnet diameter 110 mm
cutting according to flag
Mounting depth according to flag
dimensions Ø 115 mm x 53 mm
Weight 1.7 kg
Speaker Power (W RMS)60.0
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)100.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)18000
