By buying this product you get 20 loyalty points
This high-midrange and high-pitched horn stands out for its extreme linearity of response over a wide frequency band, to the limits of the audible without additional tweeter.
Its high efficiency allows the coupler to any speaker less than 96 dB sensitivity.
Can be used as an extreme high-strength but also high-medium reinforcement, it gives a great impression of clarity and warm presence of these registers, an unusual sharpness without metallic sound for fast reproduction in agreement with SUPRAVOX products.
Cut-off frequency | 2000 to 20 kHz +/- 1.5 dB |
<sensitivity/ Span> | 96 dB / W at 1m |
impedance | 8 ohms |
Horizontal Dispersion | 60 ° |
Vertical Dispersion | 30 ° |
Width of mouthpiece | 180 mm |
Height | 90 mm |
Depth | 110 mm |
Weight | 0.5 kg |
Speaker Power (W RMS) | NC |
Speaker Type | Horn loudspeaker |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | N/A |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | 96.0 |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | 2000 |
Highest frequency (Hz) | 20000 |
