The IEC C14 Eizz EZ-7030 plug offers a magnificent quality of manufacture, using high performance materials, promoting excellent electrical conductivity and durability. The contacts of the connector are made of tellurium copper with 200µ Palladium/Rhodium plating, the whole maintained by a PTFE insulating body. The contacts allow the assembly of large conductors, up to 3.7mm in diameter. The assembly is very simple with a screw system.
Product type | IEC C14 plug |
Contacts material | Tellurium copper |
Contacts plating | Palladium/Rhodium |
Max conductors diameter | Ø3.7mm |
Insulation | PTFE |
Mounting type | To screw |
Mounting holes spacing | 40mm |
Max cable diameter (mm) | 3.7 |
Mounting type | To weld |
Connectic | Male |
Connector | IEC C14 |
Contacts Material (Connector) | Tellurium Copper |
Contacts Plating (Connector) | Palladium |
Contacts Plating (Connector) | Rhodium |
Rated current (A) | 10.0 |
