Par contre, absence de réducteur et j'ai dù moi aussi mettre du scotch pour augmenter le diamètre.
This Hi-Fi adaptor, developed in France, was created to be used with almost every cable in the market.
With this adaptor you can connect your cable directly to your device, suppress all your IEC connection or add another power cable to your device without the need of a compatible entry.
With the same format as an IEC connector, so you can change it in an easy way.
The cable is locked with the help of a clinch claw which supports cables from 12.5 to 15.5mm.
This clinch claw allows you cable to be always aligned and centered whatever it is the cable diameter.
Caracteristics :
Max cable diameter (mm) | 16.5 |
Mounting type | To screw |
Connectic | Female |
Connector | N/A |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | N/A |
Rated current (A) | N/A |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Marc A.
CHRISTOPHE J.
