IEC C14 Socket
This IEC C14 socket is ideal for integration into a DIY device as a power connector. The base incorporates an ON/OFF switch for powering your device and a fuse holder (fuse sold separately) to protect your system.
Reference : 20489
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 29-04-2025.
IEC C14 Socket With ON-OFF Toggle Switch and Fuse Holder 250V 10A Black
Embase IEC C14 : Front view
Embase IEC C14 : Dimensions
Product typeIEC C14 Socket
ON-OFF switchYes
Fuse holderYes (fuse solde separately)
Voltage / Current250VAC 10A
Insulation resistance≥ 100MΩ
Dielectric strength≥2000V/1min
Insert / Extract force5-30N
Mounting panel thickness1mm
Dimensions50 x 30.6 x 27.5mm
PackageSold by unit
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Contacts Plating (Connector)Nickel
Rated current (A)10.0
This IEC C14 socket is ideal for integration into a DIY device as a power connector. The base incorporates an ON/OFF switch for powering your...
