FURUTECH FI-03 (G) IEC Plated Gold Plated Fuse 5x20mm
Reference : 5019
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 23-04-2025.
FURUTECH FI-03G IEC Plated Gold Plated Fuse 5x20mm
IEC socket with 5x20mm holder for 10A / 250V fuse
Gold plated (Fuse not supplied)
Technical specifications:
• Copper alloy coated conductor α (Alpha)
• PBT and fiberglass chassis
• Dimensions: 44.0mm (L) x 28.6mm (D) x 33.0 (H)
• Capacity: 10A / 250V
• Standard: IEC 320-1 C14
• Approvals: UL / CSA / VDE / DEMKO / SEMKO / NEMKO / FIMKO
https://www.audiophonics.fr/images2/5019/5019_FURUTECH_FI-03_2.jpg
https://www.audiophonics.fr/images2/5019/5019_FURUTECH_FI-03_1.jpg
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Rated current (A)10.0
6 reviews
The typical furutech quality, nothing to add.
This review has been posted for FURUTECH FI-03 (G) IEC Plated Gold Plated Fuse 5x20mm
Suprise sur le gâteau
Ne cherchez plus, pour un prix dérisoire vous gagnez sur toute la ligne.
Changer juste cette embase vous donnera un son beaucoup plus naturel que l'origine. (Metalique , froid
) Les timbres plus juste, l'image sonore mieux défini et surtout les effets FX sur les instruments que l'on
entend plus longtemps . A soudé avec étain 10 % argent .
great mod for every high resolution system
The heart of my System is a "ANK 5.1 signature" tube DAC. I use the "Audio Magic Premiere Ultimate" fuse already. Yesterday I changed the series inlet against the furutech one. It was more the obvious, that this inlet can be a real bottleneck for the whole system. After modification, you have more of evereything. More room, higher resolution, deeper bass, etc.
Good quality inlet that improves sound quality.
Belle pièce
Construction parfaite, pour un produit parfait, que demander de mieux ?
