FURUTECH FI-09 NCF (R) IEC Inlet Rhodium plated Pure Copper
By buying this product you get 33 loyalty points
Reference : 11338
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 24-04-2025.
The FURUTECH FI-09 NCF (R) IEC Inlet Rhodium plated Pure Copper - Nano Crystal² Formula – Nano Crystalline, Ceramic and Carbon Powder.
Incorporated into new NCF series of Furutech products, Nano Crystal² Formula — NCF is comprised of a special crystalline material that has two “active” properties. First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared. Furutech then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional “Piezo Effect” damping properties.
The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material – only found in Furutech products !
NCF Furutech Technologie
Characteristics :
  • α (Alpha) Pure-Copper Rhodium-plated Conductor
  • Materials: Nylon/fiberglass with special “NCF” anti-resonance damping material - nano-sized crystalline, piezo ceramic particles and carbon powder
  • Specifications: Accommodates wire diameters up to 4.0mm (set-screw)
  • Dimensions: 60.5 (W) x 30.2mm (D) x 36.2mm (H) ±0.1mm
  • Type: 2-pole+earth, Rated: 15A/250V
  • Sold individually
Max cable diameter (mm)4.0
Mounting typeTo screw
ConnecticMale
ConnectorType B (NEMA)
Rated current (A)15.0
