FURUTECH FI-INLET IEC Rhodium Plated
The contacts of this Furutech IEC receptacle benefit from the brand's α (Alpha) treatment. This consists of a two-step process to maximise conductor performance.
Reference : 17580
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 24-04-2025.
INLET IEC FURUTECH
FI-INLET RHODIUM Plated
Furutech e-TP60E NCF Distributeur Secteur 6 Prises Plaqué Or
α (Alpha) treatment
The contacts of this Furutech IEC socket benefit from the brand's α (Alpha) treatment. This consists of a two-step process, aimed at maximizing driver performance. The first step, cryogenics, brings the conductive material to a temperature between -196°C and -250°C. The treated elements then change their molecular structure, improving the electrical conductivity of the material. The second phase consists of exposing these same elements to a very effective demagnetization process, totally eliminating the magnetization of the material.
Product typeINLET IEC
Conductor materialCopper Alloy with anti-magnetic"Furutech Alpha α" treatment
Conductor platingRhodium
Body materialPBT and fiberglass housing
Type de montage4.8mm terminals or to weld
Nominal tension 15A/125V - 10A/250V
Dimensions (LxDxH)49.5 x 22 x 27.5 mm
Drilling spacing40mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Rated current (A)15.0
Rated current (A)10.0
The contacts of this Furutech IEC receptacle benefit from the brand's α (Alpha) treatment. This consists of a two-step process to...
