IEC Base EMI / RFI noise filter 230V 3A with Fuse Holder
4.8 / 5
Reference : 11614
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 07-01-2025.
This high performance mains filter is designed to filter disturbances when the capacitors are insufficient. It meets strict building standards.
Single-phase male IEC model , this filter accepts as input a voltage of 250Vmaximum andservice currents that can reach 3A.
Its effectiveness is daunting against electromagnetic interference (EMI) propagated by radiation or conduction.em>
Specifications:
  • Operating Voltage: 250V Max 50 / 60Hz
  • Service Current: 3A Max
  • Operating Temperature Range: -25 ° C to + 85 ° C
  • Components used: Self 2X1.8MH, capacitor 1X0.1μF and 2X3300pF
  • Certifications: UL 1283, CSA 22.2, IEC / EN 60939
  • Fuse supplied: 3.15A 250V
  • Weight: 48g
  • Recessed dimensions: 50X32x27mm
filtre secteur 10A
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Rated current (A)3.0
4 reviews
Long delivery time
Paid on October 29th, today is Nov. 7th. After five days, tracking still says: "02/11/2023 Your package is in transit in our network". Usually, intereuropean shipping, especially with parcel services (this one goes through DPD) lasts for around 3 days.
This review has been posted for IEC Base EMI / RFI noise filter 230V 3A with Fuse Holder
Filtro antirumore 230V
Sono soddisfatto del prodotto di cui nemmeno sapevo dell'esistenza. Risolve problemi di disturbi provenienti dalla rete di alimentazione. Molto soddisfatto dell'acquisto
Matériel conforme à la commande, livraison rapide, je recommande fortement ce site.
Belle performance
J’ai cherché à améliorer mon ampli Rega Elicit 1ére génération en mettant cette embase filtre secteur , une par transformateur, soit deux car cet ampli est un vrai double mono. Résultat après modification une plus grande clarté en haut , au milieu & surtout en bas du spectre musicale .
Je vous le conseil dons sans aucune retenue, en plus pour une somme modique .
