IEC C14 Plug with ON-OFF Switch 250V 10A Black
This IEC C14 subbase is ideal for integration into a DIY device as a power supply connector. The base plate is also accompanied by an ON/OFF toggle switch to turn on your device.
Reference : 14104
2,00 €tax incl.
1,67 € tax excl.
Shipping date: 22-04-2025.
IEC Plug + Switch
Embase IEC C14 avec Interrupteur à Bascule ON-OFF 250V 10A Noir
Product typeIEC Plug
ON/OFF Switch
IEC TypeC14
Voltage / Current250V 10A
Dimensions41 x 30.1 x 31.8mm
Cutout dimensions40 x 26.8mm
Weight16g
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
LED ColorN/A
ConnectorIEC C14
Contacts Plating (Connector)Nickel
Internal widthN/A
Internal depthN/A
Internal heightN/A
Number of positions2
Button type1NO1NC
This IEC C14 subbase is ideal for integration into a DIY device as a power supply connector. The base plate is also accompanied by an ON/OFF toggle...
