IEC C14 Plug with ON-OFF Toggle Switch and Fuse 250V 10A Black
This IEC C14 socket is ideal for integration into a DIY device as a power connector.  The socket incorporates an ON/OFF toggle switch for powering your device and a fuse to protect your system.
Reference : 14341
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 22-04-2025.
IEC C14 Plug
Embase IEC C14 avec interrupteur à bascule ON-OFF et fusible 250V 10A noir
Product typeIEC C14 plug
ON-OFF switch
Fuse
Voltage / Current250VAC 10A
Insulation resistance≥ 100MΩ
Dielectric strength≥2000V/1min
Insert / Extract force5-30N
Total dimensions50 x 30.6 x 27.5mm
Mounting panel thickness2mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Contacts Plating (Connector)Nickel
Rated current (A)10.0
This IEC C14 socket is ideal for integration into a DIY device as a power connector.  The socket incorporates an ON/OFF toggle switch for...
