IEC C8 2-Pole Connector
This standard 2-pin IEC C8 socket will allow you to add a power connector to your DIY projects or replace a faulty one.
Reference : 3691
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 24-04-2025.
IEC Connector
C8 Type 2 Poles
Embase IEC C8
Voltage / Current250V 10A
Connector typeIEC C8 (male)
Connection typeTo solder
Housing materialPlastic
Dimensions35 x 15.1 x 16.7mm
Fixation holes spacing28mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C8
Rated current (A)10.0
bon matos
facile à souder,elle s'adapte très bien avec les cables testés.de bien meilleure facture que ce que l'image peut laissé supposer
This review has been posted for IEC C8 2-Pole Connector
