VIBORG VI20G IEC C20 Socket Silver / Gold Plated Copper Ø4.6mm
The Viborg CI20G is a high quality IEC C20 power supply connector. It uses pure copper contacts with triple plating of OFC copper, silver and 24k gold, ensuring both perfect electrical conductivity and excellent durability.
Reference : 15908
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 24-04-2025.
Viborg VI20G
Viborg VI20G Embase IEC C20 Cuivre Plaqué Argent / Or Ø4.6mm
The Viborg CI20G is a high quality IEC C20 power supply connector. It uses pure copper contacts with triple plating of OFC copper, silver and 24k gold, ensuring both perfect electrical conductivity and excellent durability. The body of the connector is made of DuPont PA66GF33 polyamide reinforced with glass fiber. The connector accepts conductors up to 4.6mm in diameter. The connector is easily mounted with screws and does not require soldering.
Product typeIEC C20 Socket
Contacts amterialPure copper (purity: 99.998%)
Contacts materialOFC Copper
Silver
Gold 24k
Body materialFiberglass reinforced DuPont PA66GF33 polyamide
Max conductors diameterØ4.6mm
Voltage/Current250V 16A
125V 20A
Mounting typeTo screw
Cutout diameter36 x 30mm
Dimensions60.5 x 38.95 x 30mm
Max cable diameter (mm)4.6
ConnecticMale
ConnectorIEC C20
Rated current (A)20.0
Rated current (A)16.0
The Viborg CI20G is a high quality IEC C20 power supply connector. It uses pure copper contacts with triple plating of OFC copper, silver and 24k...
