7HZ TIMELESS II In-Ear Monitors
The 7HZ TIMELESS II in-ear monitors, an evolution of the brand's TIMELESS range, are planar-magnetic IEMs featuring a new 14.5mm diameter driver. This driver is itself driven by two arrays of N52 magnets, offering a high level of response for exceptional dynamics.
Reference : 20432
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 24-04-2025.
7HZ Timeless II In-Ear Monitors IEM Planar Magnetic Ø14.5mm 15.2 ohm 108dB 5Hz-40kHz
Photo des écouteurs 7HZ TIMELESS II
The 7HZ Timeless II in-ear monitors, an evolution of the brand's Timeless range, are planar-magnetic IEMs featuring a new 14.5mm diameter driver. This driver is itself driven by two arrays of N52 magnets, offering a high level of response for exceptional dynamics. The 7HZ Timeless II are also easy to drive, thanks to their 15.2 ohm impedance and 108dB sensitivity. In addition, their extended frequency response from 5Hz to 40kHz ensures rich, detailed reproduction. Added to this are numerous improvements such as the possibility of using filter tips for precise adjustment of the frequency curve, and a new, more optimal acoustic cavity. Finally, a high-end audiophile cable with interchangeable termination lets you choose between a 3.5mm jack and a balanced 4.4mm jack. Earphones are connected via 0.78mm CIEM connectors.
7HZ Timeless II: New planar magnetic driver
The 7HZ Timeless II in-ear monitor features a new planar magnetic driver measuring no less than 14.5mm in diameter. The driver features a dual-sided silver alloy coating just a few microns thick. In addition, a network of N52 magnets drives the whole system, offering a superior level of rendering.
Le driver des 7HZ TIMELESS II
Les embouts de filtrage des 7HZ TIMELESS II
7HZ Timeless II: Tunable nozzles
The 7HZ Timeless II feature 3 nozzles for adjusting the sound quality of the IEMs. Derived from the concept of phase plugs for loudspeakers, they provide precise adjustment, enabling the earphones to be adapted to an eclectic music library.
7HZ Timeless II: An optimum acoustic cavity
The new Timeless II acoustic cavity features a 7-layer design with double venting and a more secure locking system for the driver. This locking system gives the driver greater stability for improved durability and rigidity.
La cavité acoustique des 7HZ TIMELESS II
7HZ Timeless II: A detachable audiophile cable
The 7HZ Timeless II cable features 4 ultra-pure 7N single-crystal copper conductors. Furthermore, it features 0.78mm CIEM connectors on the headphone side and interchangeable 3.5mm or balanced 4.4mm jack termination.
Le package des 7HZ TIMELESS II
Product typeIn ear monitors
Speakers typePlanar magnetic
Driver diameterØ14.5mm
Impedance15.2 ohms
Sensitivity108db/V @ 1KHz
THD< 0.2%/1KHz
Frequency response5Hz-40KHz
IEM connectorsCIEM 0.78mmm
Cable terminaisonInterchangeable 3.5mm jack / 4.4mm jack
Cable conductorsSingle-crystal pure copper
Weight5g/earphone
Package1x Timeless II 7HZ in-ear monitors
1x CIEM 0.78mm detachable cable to interchangeable termination
1x 3.5mm jack termination
1x 4.4mm jack termination
3x Filter tips
10x Pair of ear tips
1x Storage box
Impedance (Ω)15.2
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)5
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
7HZ TIMELESS II In-Ear Monitors IEM Planar Magnetic Ø14.5mm 15.2 ohm 108dB 5Hz-40kHz
The 7HZ TIMELESS II in-ear monitors, an evolution of the brand's TIMELESS range, are planar-magnetic IEMs featuring a new 14.5mm diameter...
