DUNU FALCON ULTRA In-Ear Monitors IEM Dynamic Drivers 16 Ohm 108dB 5Hz-40kHz
With the Falcon Ultra, Dunu unveils high-end in-ear monitors that combine performance and design. They feature dynamic drivers perfectly designed to deliver rich, musical sound reproduction. They also come with a complete package enabling the earphones to adapt to every need.
By buying this product you get 27 loyalty points
Reference : 18264
275,00 €tax incl.
229,17 € tax excl.
Shipping date: 16-04-2025.
Dunu Falcon Ultra
Dunu Falcon Ultra Écouteurs Intra-Auriculaires IEM Haut-Parleurs Dynamiques 16 Ohm 108dB 5Hz-40kHz
Dynamic drivers
Dunu Falcon Ultra adopt the second generation of ECPLISE dynamic drivers. These feature a lightweight, ultra-rigid lithium-magnesium magnet diaphragm, flexible independent suspension, a high-flux magnetic circuit and a high-performance airflow control system. Careful, meticulous design enables these IEMs to deliver a rich, precise sound for high-quality listening.
Lightweight, rigid membrane
Falcon Ultra's lithium-magnesium alloy metal diaphragm offers a particularly light and rigid structure. This ensures fast response and excellent sonic precision, as well as low distortion for a natural, transparent response.
High-performance magnetic circuit
The Falcon Ultra features a high-performance magnetic circuit, generating high magnetic flux for excellent dynamics. The result is lively, faithful sound reproduction.
Multiple airflows
Precisely designed and positioned, several ventilation holes improve airflow within the earcups. Once again, this design not only improves the dynamics of the IEMs, but also their low-frequency response.
Two sound profiles
Dunu Falcon Ultra are equipped with two acoustic tubes using different materials: stainless steel (blue) and gold-plated copper alloy. By changing these tubes, you can quickly modify the sound signature of the headphones. The former offer a clear, transparent sound with rapid response. The latter, on the other hand, offer a richer, smoother sound, especially for vocals.
Interchangeable cable connection
The Dunu Falcon Ultra cable features the Q-Lock Lite system for interchangeable connectors. The cable is supplied with a 3.5mm single-ended and a 4.4mm balanced jack connector, making it suitable for a wide range of devices.
An efficient cable
Falcon Ultra earphones come with a cable made of silver-plated, single-crystal copper braided Litz wire. This ensures excellent conductivity for perfect audio signal transmission.
MMCX connectors
The Dunu Falcon Ultra adopts standard MMCX connectivity. As the cable is detachable, it can be replaced as required.
A complete package
Dunu Falcon Ultra come with a complete package. These include a storage pouch and case, cable, 6.35mm jack connector, acoustic tubes and several ear-tips.
S&S eartips (Stage & Studio)
The S&S tips developed by Dunu are made of flexible silicone. They have a straight format and offer excellent soundstaging and natural sound.
Candy eartips
The brand's new Candy tips are also made of silicone. They feature a thicker tube to ensure good imaging and richness of sound.
Balanced eartips
These gray tips are the standard models, designed to provide balanced, accurate sound reproduction for the vast majority of musical genres.
Voice eartips
These blue earmolds accentuate the clarity of human voices. They are therefore particularly suitable for musical genres in which the voice is a central element.
Product typeIn-ear monitors (IEM)
Impedance16 Ohm @ 1kHz
Sensitivity108dB +/-1dB @ 1kHz
THD< 0.3% @ 1kHz
Frequency response5Hz - 40kHz
Dynamic driversSecond-generation ECLIPSE drivers with Lithium-Magnesium metal cone
Housing materialS316 Stainless steel
CableSilver-plated monocrystalline copper Litz wires
Cable length1.2m
Earphone connectorsMMCX
Cable connectorInterchangeable connector with Q-Lock Lite system: 3.5mm single-ended jack / 4.4mm balanced jack
ColorBlue
ColorBlue
Impedance (Ω)16
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)5
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorMMCX
Phone call featureNo
Noise reductionNo
With the Falcon Ultra, Dunu unveils high-end in-ear monitors that combine performance and design. They feature dynamic drivers perfectly designed...
