DUNU KIMA CLASSIC In-Ears Monitor
DUNU Kima Classic in-ear earphones feature a dynamic DLC (Diamond-like carbon) driver of no less than Ø10mm, Neodymium N52 magnets and an ultra-thin, high-voltage voice coil for a high level of performance.
Reference : 19181
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 23-04-2025.
DUNU KIMA ClassicDynamic In Ears Monitor IEM 32 Ohm 108dB 5Hz-40kHz
DUNU KIMA CLASSIC IEM Picture
DUNU Kima Classic in-ear monitors feature a dynamic DLC (Diamond-like carbon) driver of no less than Ø10mm, Neodymium N52 magnets and an ultra-thin, high-voltage voice coil for a high level of performance. In addition, their dual-cavity structure effectively eliminates unwanted resonances. The DLC diaphragm in Kima Classic IEMs is not a traditional diaphragm. In fact, this new, more uniform generation improves rigidity and damping characteristics for a considerable reduction of harmonic distortion. All in all, these earphones offer clean, natural sound reproduction combined with a soft, warm sound signature.
DUNU Kima Classic frequency response
DUNU Kima Classic: optimized airflow control
DUNU Kima Classic in-ear earphones feature a microcontroller that creates a unique system for microcontrolling airflow in the front and rear chambers of the earphones.
Photo des IEM DUNU Kima
Photo du câble des IEM DUNU KIMA
DUNU Kima Classic: an audiophile cable
The cable accompanying the DUNU Kima Classic is a Litz wire-structured cable with silver-plated single-crystal pure copper conductors. Shielding and external insulation protect the signal from interference. Universal, it features two 0.78mm CIEM connectors and a 3.5mm jack termination on both sides of the cable. CIEM connectors feature identification rings for quick pairing with earphones.
Product typeIn-ear monitors
DiaphragmDynamic DLC
Diaphragm diameterØ10mm
Impedance32Ω @ 1kHz
Frequency response5Hz-40kHz
Sensitivity108 ± 1 dB @ 1kHz
THD+N< 0.3% @ 1kHz
Cable typeRemovable
Cable length1.2m
Cable conductor materialSiver-plated pure copper
Cable connectorsCIEM 0.78mm
Cable terminaisonJack 3.5mm
Weight15g
ColorGris
Package1x DUNU Kima Classic in-ear monitors
1x Cable 2x CIEM 0.78MM to jack 3.5mm
9x Pair of ear tips
1x 3.5mm jack to 6.35mm jack adapter
1x Storage pouch
ColorGray
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)5
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
DUNU KIMA CLASSIC Dynamic In Ears Monitor IEM 32 Ohm 108dB 5Hz-40kHz
DUNU Kima Classic in-ear earphones feature a dynamic DLC (Diamond-like carbon) driver of no less than Ø10mm, Neodymium N52 magnets and...
