DUNU TALOS Hybrid In-Ear Monitors IEM Planar Magnetic + Balanced Armature 16 Ohm 100dB 5Hz-40kHz
The Dunu Talos in-ear monitors are a hybrid model featuring both a 14.6mm Planar Magnetic driver and two custom Balanced Armature drivers embedded in an innovative architecture. They are equipped with a switch that allows you to switch between Planar and Hybrid Planar modes for a unique sound experience. In Planar mode, the Talos provide a smooth, natural and warm sound for long listening sessions. The Hybrid setting, on the other hand, promotes a transparent, accurate and detailed sound.
Reference : 17289
249,00 €tax incl.
207,50 € tax excl.
Dunu Talos
Hybrid In-Ear Monitors IEM Planar Magnetic + Balanced Armature 16Ω 100dB 5Hz-40kHz
Dunu Talos Écouteurs intra-auriculaires IEM hybrides Planar Magnetic + Balanced Armature 16Ω 100dB 5Hz-40kHz
Planar Magnetic 14.6mm speaker
The Dunu Talos are equipped with a brand new Planar Magnetic driver with an ultra-thin 14.6mm diaphragm. It uses an extremely light silver alloy coil and a double-sided N55 magnetic circuit. It is tuned to perfectly reproduce the entire frequency range, with very low distortion and fast transients.
Dual Balanced Armature Custom Speakers
Talos also features two specially tuned and optimized Balanced Armature drivers. These are particularly comfortable in the reproduction of high and ultra-high frequencies, ensuring a transparent response and great clarity for enjoying music in all its details.
Ergonomic, high-performance headphones
The body of the Dunu Talos is ergonomically shaped, precision-machined from aluminum alloy using CNC (computer numerical control) for optimum wearing comfort. Each earpiece incorporates gold-plated brass acoustic cavities to ensure natural sound. Multiple vents on the earphone shell form a unique airflow microcontrol system to ensure dynamic sound and deep bass.
Detachable silver-plated copper cable
The Dunu Talos come with a detachable cable with silver-plated single crystal copper conductors, providing excellent conductivity for perfect signal transmission. The cable connects to the headphones via standard 2-pin CIEM 0.78mm connectors.
Product typeIn-ear monitors
Impedance16Ω
Sensitivity100dB ±1dB @ 1kHz
Frequency response5Hz - 40kHz
Drivers1* Planar Magnetic 14.6mm
2* Balanced Armature
Operating modesPlanar mode: switch position "I"
Planar + BA hybrid mode: switch position "ON"
Length of the cable1.2m
Earphones connectorCIEM 0.78mm
Cable conductorsSilver plated copper
Connectors body materialAluminum
Weight14g
Impedance (Ω)16
Efficiency / Sensitivity (dB)100.0
Lowest frequency (Hz)5
Highest frequency (Hz)40000
The Dunu Talos in-ear monitors are a hybrid model featuring both a 14.6mm Planar Magnetic driver and two custom Balanced Armature drivers embedded...
