By buying this product you get 99 loyalty points
FiiO FA19 in-ear monitors are high-end earphones. They feature a 3-way design with 5 Balanced armature drivers per earphone. Specially designed for the most demanding audiophiles, their design and performance come close to excellence, delivering sound quality of the highest order. Each transducer works in harmony with its peers for perfect rendering in all circumstances, even for the most complex audio passages. The FiiO FA19s also feature a Monitor and Hi-Fi mode selector, allowing you to adapt the rendering to the desired use. Monitor mode delivers crisp, detailed sound for more professional use, while Hi-Fi mode enhances bass and midrange for a more immersive, pleasant experience. A detachable MMCX cable with interchangeable 3.5mm jack and balanced 4.4mm jack termination completes the package. This audiophile cable is made of a total of 8 multi-stranded conductors for a total of 228 pure silver wires, providing enhanced signal conductivity and optimizing sound clarity. All the features and functions of the FiiO FA19 make it an excellent choice for users seeking excellence.
The use of 10 Knowles balanced armature transducers, carefully calibrated to work in harmony with their peers, extends the FA19's frequency response from 20Hz to 40KHz. The 3-way design features 4 transducers for bass, two for midrange and 4 for treble. This configuration ensures richly detailed, clear sound reproduction across their entire frequency range. The FiiO FA19 IEM transducers optimize the airflow inside the earphones for deep, punchy bass. A dedicated midrange notch filter avoids sibilance and audiophile capacitors. Rubycon ensures crossover points with surgical precision. Thanks to these crossovers, high frequencies benefit from an extended frequency range, while remaining fine and detailed.
Featuring FiiO's proprietary S.Turbo technology, the FA19 boasts optimized bass diffusion for an immersive sound experience. Bass remains precise and clear, leaving plenty of room for midrange and treble. The result is a pleasant, balanced listening experience.
A switch allows two operating modes to be selected, so that the listening session can be adapted to the desired use of the headphones. Monitor mode is reserved for more professional use, with clean, detailed reproduction. This ensures faithful, precise reproduction of recordings. Hi-Fi mode, on the other hand, enhances midrange and bass for a more pleasant, immersive listening experience. The Hi-Res certification of the FiiO FA19 in-ear monitors ensures that they meet the highest standards and are capable of meeting professional needs.
The high-quality cable accompanying the FiiO FA19 has a Litz wire structure and rests on 8 individually insulated 28-strand pure silver conductors. The Litz wire structure and pure silver strands ensure optimum signal conductivity and reduce potential interference during signal transmission. The cable features MMCX connectors and an interchangeable termination. FiiO offers the option of a 3.5mm jack termination or a balanced 4.4mm jack termination for a high level of compatibility.
Featuring a photosensitive resin shell machined using DLP-3D printing technology, FiiO FA19s are effectively protected. This lightweight, durable shell also offers a refined, high-end aesthetic. These headphones are specially designed to fit the shape of the ear, allowing extended use without discomfort.
Product type | In-ear monitors |
Transducers | 2x Knowles Balanced armature custom bass transducers 2x Knowles Blanced armature bass transducers 2x Knowles ED Balanced Armature midrange transducers 4x Knowles SWFK Balanced Armature treble transducers |
Conception | 3 way |
Frequency response | 20Hz-40kHz |
Impedance | 10Ω @ 1 kHz |
Sensibility | 106dB/mW @ 1kHz |
Cable | Detachable |
Cable length | 1.2m |
Earphone connectors | MMCX |
Cable terminaison | Interchangeable: 3.5mm jack / 4.4mm balanced jack |
Cable structure | 8 strands with a total of 228 high purity silver wires in litz wire struture |
Color | Transparent / Black |
Weight | 7g/earphone |
Package | 1x FiiO FA19 in-ear monitors 1x MMCX detachable cable to interchangeable termination 1x 3.5mm jack termination 1x Balanced 4.4mm jack termination 1x Magnetic cord clip 1x HB5 storage case 1x Cleaning brush 1x MMCX quick release tool 11x Pair of in-ear ear tips (Foam/Bass/Spinfit/HS18) |
Color | Black |
Color | Transparent |
Impedance (Ω) | 10 |
Efficiency / Sensitivity (dB) | 106.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 4.4mm |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | MMCX |
Phone call feature | No |
Noise reduction | No |
