FiiO FA19 In-ear Monitors
FiiO FA19 in-ear monitors are high-end earphones. They feature a 3-way design with 5 Balanced armature drivers per earphone. Specially designed for the most demanding audiophiles, their design and performance come close to excellence, delivering sound quality of the highest order.
By buying this product you get 99 loyalty points
Reference : 19909
990,00 €tax incl.
825,00 € tax excl.
FiiO FA19 In-ear Monitors 3-Way Balanced Armature 10 Ohm 106dB 20Hz-40kHz
Photo des FiiO FA19
FiiO FA19 in-ear monitors are high-end earphones. They feature a 3-way design with 5 Balanced armature drivers per earphone. Specially designed for the most demanding audiophiles, their design and performance come close to excellence, delivering sound quality of the highest order. Each transducer works in harmony with its peers for perfect rendering in all circumstances, even for the most complex audio passages. The FiiO FA19s also feature a Monitor and Hi-Fi mode selector, allowing you to adapt the rendering to the desired use. Monitor mode delivers crisp, detailed sound for more professional use, while Hi-Fi mode enhances bass and midrange for a more immersive, pleasant experience. A detachable MMCX cable with interchangeable 3.5mm jack and balanced 4.4mm jack termination completes the package. This audiophile cable is made of a total of 8 multi-stranded conductors for a total of 228 pure silver wires, providing enhanced signal conductivity and optimizing sound clarity. All the features and functions of the FiiO FA19 make it an excellent choice for users seeking excellence.
FiiO FA19: a total of 10 Balanced Armature transducers
The use of 10 Knowles balanced armature transducers, carefully calibrated to work in harmony with their peers, extends the FA19's frequency response from 20Hz to 40KHz. The 3-way design features 4 transducers for bass, two for midrange and 4 for treble. This configuration ensures richly detailed, clear sound reproduction across their entire frequency range. The FiiO FA19 IEM transducers optimize the airflow inside the earphones for deep, punchy bass. A dedicated midrange notch filter avoids sibilance and audiophile capacitors. Rubycon ensures crossover points with surgical precision. Thanks to these crossovers, high frequencies benefit from an extended frequency range, while remaining fine and detailed.
Photo de l'intérieur du FiiO FA19
Zoom sur la technologie S.Turbo des FiiO FA19
FiiO FA19: proprietary S.Turbo technology
Featuring FiiO's proprietary S.Turbo technology, the FA19 boasts optimized bass diffusion for an immersive sound experience. Bass remains precise and clear, leaving plenty of room for midrange and treble. The result is a pleasant, balanced listening experience.
FiiO FA19: Monitor and Hi-Fi modes
A switch allows two operating modes to be selected, so that the listening session can be adapted to the desired use of the headphones. Monitor mode is reserved for more professional use, with clean, detailed reproduction. This ensures faithful, precise reproduction of recordings. Hi-Fi mode, on the other hand, enhances midrange and bass for a more pleasant, immersive listening experience. The Hi-Res certification of the FiiO FA19 in-ear monitors ensures that they meet the highest standards and are capable of meeting professional needs.
Mode monitor et mode Hi-Fi des FiiO FA19
FiiO FA19: audiophile cable
The high-quality cable accompanying the FiiO FA19 has a Litz wire structure and rests on 8 individually insulated 28-strand pure silver conductors. The Litz wire structure and pure silver strands ensure optimum signal conductivity and reduce potential interference during signal transmission. The cable features MMCX connectors and an interchangeable termination. FiiO offers the option of a 3.5mm jack termination or a balanced 4.4mm jack termination for a high level of compatibility.
Photo du câble des FiiO FA19
FiiO FA19: ergonomics and optimum comfort
Featuring a photosensitive resin shell machined using DLP-3D printing technology, FiiO FA19s are effectively protected. This lightweight, durable shell also offers a refined, high-end aesthetic. These headphones are specially designed to fit the shape of the ear, allowing extended use without discomfort.
Ergonomie et confort des FiiO FA19
Product typeIn-ear monitors
Transducers2x Knowles Balanced armature custom bass transducers
2x Knowles Blanced armature bass transducers
2x Knowles ED Balanced Armature midrange transducers
4x Knowles SWFK Balanced Armature treble transducers
Conception3 way
Frequency response20Hz-40kHz
Impedance10Ω @ 1 kHz
Sensibility106dB/mW @ 1kHz
CableDetachable
Cable length1.2m
Earphone connectorsMMCX
Cable terminaisonInterchangeable: 3.5mm jack / 4.4mm balanced jack
Cable structure8 strands with a total of 228 high purity silver wires in litz wire struture
ColorTransparent / Black
Weight7g/earphone
Package1x FiiO FA19 in-ear monitors
1x MMCX detachable cable to interchangeable termination
1x 3.5mm jack termination
1x Balanced 4.4mm jack termination
1x Magnetic cord clip
1x HB5 storage case
1x Cleaning brush
1x MMCX quick release tool
11x Pair of in-ear ear tips (Foam/Bass/Spinfit/HS18)
ColorTransparent
Impedance (Ω)10
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Headphone / Earphone connectorMMCX
Phone call featureNo
Noise reductionNo
FIIO FA19 In-Ear Monitors 3-Way Balanced Armature 10 Ohm 106dB 20Hz-40kHz
FiiO FA19 in-ear monitors are high-end earphones. They feature a 3-way design with 5 Balanced armature drivers per earphone. Specially designed for...
