FIIO FH15 In-Ear Monitors IEM 1x Dynamic Driver / 3x Knowles Balanced Armature Drivers 16 Ohm
The FiiO FH7S in-ear monitors features no less than five intelligently integrated drivers, revealing a rich and musical sound. The 13.6mm DLC dynamic driver is accompanied by four Balanced Armature drivers from Knwoles.
By buying this product you get 22 loyalty points
Reference : 17610
229,00 €tax incl.
190,83 € tax excl.
FiiO FH15
An exceptional design
The FiiO FH15 earphones feature no less than four intelligently integrated speakers, thus revealing a sound of great richness and musicality. This hybrid model has 3 balanced armatures for the midrange and treble as well as a dynamic carbon transducer for the bass.
10mm carbon dynamic speaker
The FiiO FH15 uses DLC (Diamond Like Carbon) carbon for the diaphragms of their dynamic drivers allowing them a very high responsiveness to the audio input signal. For the same volume, carbon DLC is 1/4 lighter than Bellyrium which leads to a reduction in distortion and an even more precise sound reproduction.
Custom Knowles Balanced Armature Speakers
FiiO and Knowles collaborated to create the exclusive ED BA midrange driver, with the aim of delivering richer tonal reproduction and natural, musical vocals. Regarding the treble, there are two Knowles RAD transducers. This configuration offering a very wide frequency response (10Hz - 40Khz) makes them perfect for listening to high resolution files (HI-RES).
A design of quality
These headphones from the FIIO brand have a pattern inspired by the shape of reptile scales while remaining quite sober. In addition, their shapes allow a certain comfort over long periods of listening.
Unique notch filter
After numerous analyzes and experiments, the FiiO teams have created a unique notch filter. This precisely guides the sound waves to eliminate unwanted resonances between the shell, the acoustic tube and the ear canal. The result is an effective reduction in sibilance.
S.TURBO patented acoustic design
The FiiO FH7S takes advantage of patented S.TURBO acoustic technology, enabling deep bass while maintaining the nuances and texture of your music. The sound waves are carefully guided through a turbine-shaped tube to improve the reproduction of low frequencies.
New FiiO HS18 silicone tips
The FH15 is the first model from IEM FiiO to be delivered with the new HS18 silicone tips. Thanks to a perfectly thought-out design, the surfaces in contact with the ear have a thickness reduced to 0.4mm, ensuring better comfort. These tips also have a wide opening, identical to that of the acoustic tube of the headphones, minimizing the obstacles between them and the eardrums.
High quality cable with interchangeable connectors
The cable supplied with the FH15, detachable, also benefits from an exceptional design, intended to ensure perfect transmission of the audio signal. It is thus composed of individually insulated silver-plated monocrystalline copper conductors. The Litz wire design also increases the conductive surface and limits cable resistance.
The cable is also supplied with two interchangeable connectors thanks to a screw system. You can therefore use a balanced source with the 4.4mm Jack connector or an unbalanced one with the 3.5mm Jack.
Three filters for three different sound signatures
In order to adapt to your listening, the FIIO FH15 model comes with 3 pairs of interchangeable filters that simply screw inside the acoustic tubes of each earphone. The red filter will emphasize the bass, while the black filter will give a rather balanced, transparent and clear sound. Finally, the green filter will accentuate the details in the high frequencies.
Product typeIn-Ear Monitors (IEM)
Drivers1x Dynamic driver
3x Knowles Balanced Armature drivers
Frequency response10Hz - 40kHz
Impedance16Ω @ 1kHz
Sensitivity112dB/mW @ 1kHz
Cable connectorsJack 3.5mm
Jack 4.4mm
IEM connectorsMMCX
Cable conductorsSilver plated single crystal copper (8 wires, 152 strands)
Cable length1.2m
Weight~ 6.6g / ear monitor
Package1x In-Ear IEM monitors FIIO FH15
1x Mini-jack 3,5 mm to MMCX cable (1,20 m)
1x Cleaning Tool
16x Pairs of ear tips in different sizes
3x Removable filters
1x 3.5mm jack to 4.4mm jack adapter
1x User guide
Impedance (Ω)16
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)10
Highest frequency (Hz)40000
The FiiO FH7S in-ear monitors features no less than five intelligently integrated drivers, revealing a rich and musical sound. The 13.6mm DLC...
