HIDIZS MERMAID MM2 In-Ear Monitors IEM Dual Drivers Magneto-Static / Dynamic PEK Black
The Hidizs MM2 are in-ear headphones offering very good audio performance for an immersive and convincing listening experience. A sound quality associated with a resolutely modern design with an angular aluminum face.
Reference : 16354
79,00 €tax incl.
65,83 € tax excl.
Hidizs MM2
Hidizs MM2 Écouteurs Intra-Auriculaires IEM Doubles Haut-Parleurs Dynamiques Magnétostatiques
6mm low voltage magnetostatic BM driver
The MM2 incorporates a 6mm magnetostatic BM (Balanced Membrane) driver, specifically designed by Hidizs Korean company BSE, with an extremely thin and light diaphragm, which shines with its transient response at high frequencies. A design that allows these IEMs to deliver detailed and accurate sound reproduction while ensuring a very low level of distortion.
PEK 10.2mm transducers
In addition to the BM driver, a second 10.2mm Hidizs PEK dynamic transducer with macromolecular polymer diaphragm is used to efficiently develop the bass and midrange. The MM2s are thus capable of delivering deep and fast bass, combined with rich midrange and a slight "U" curve. This is complemented by a wide soundstage with precise placement for total immersion in your music.
Three control valves for three different sound experiences
The MM2 are delivered with three interchangeable valves allowing to adapt the delivered sound to your listening and your source. The first one allows to favor the highs, the second one offers a balanced restitution and the last one allows to obtain a more powerful bass.
Resin body & Aluminum alloy
The MM2 body uses an environmentally friendly resin that is perfectly shaped to fit the ear for a comfortable fit. This resin is combined with an aluminum alloy front panel with an angular shape that is both elegant and modern.
Silver / Copper Cable
The detachable cable supplied with the MM2 benefits from a beautiful design, with OFC copper and high purity silver conductors. It allows a perfect signal conductivity between your source and the headphones.
0.78mm 2 pin CIEM connectors
The connectors on the headphone side are in CIEM 0.78mm 2 pins format and have gold plated contacts. Moreover, the cable is detachable, so it can be perfectly replaced.
Leather case
The Hidizs MM2 earphones also come with a stylish nappa leather case, protecting your IEMs from dust and splashes.
Technical specifications
Product typeIn-Ear Monitors (IEM)
Drivers typeLow voltage magnetostatic balanced membrane transducer Ø6mm
Macromolecular polymeric membrane dynamic transducer PEK Ø10.2mm
Tuning valvesSilver : treble
Rose gold : balanced
Dark red : Bass
Frequency response≤20Hz - 40kHz
Impedance18Ω @ 1kHz
Sensitivity104±1dB @ 1kHz
Nominal power5mW
Body materialResin
Aluminum alloy face and output nozzle
Cable length1.2m
Cable conductors material2x Silver conductors
2x OFC Copper conductors
Cable connectors2x CIEM 0.78mm 2 pins
1x Jack 3.5mm
Connectors contacts platingGold
Weight / earphone~ 10g
Package1x Hidizs MM2
3x Pairs of tuning valves (treble, balanced, bass)
1x Jack 3.5mm cable 1.2m
3x Pairs of tips
1x Leather carrying case
Impedance (Ω)18
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
Extra!!
Certes je poste mon avis avec 2 ans de retard! Ces petits écouteurs intra sont d'une qualité exceptionnel par rapport à leur prix de vente. La possibilité de pouvoir changer les filtre en fonction de ses goût et vraiment génial, de plus leur rendu acoustique dépasse mes attentes pour type de casque. Bref une petite pépite qui n'est malheureusement plus proposée à la vente au moment ou je me décide enfin à donner mon avis....
This review has been posted for HIDIZS MERMAID MM2 In-Ear Monitors IEM Dual Drivers Magneto-Static / Dynamic PEK Black
The Hidizs MM2 are in-ear headphones offering very good audio performance for an immersive and convincing listening experience. A sound quality...
