Ecouteurs corrects, on sent bien les basses, aigus.
In-Ear Monitor IEM Dynamic Drivers 20Ω 112dB 20Hz-40kHz
Hidizs proposes with its in-ear earphones MS1 a powerful model and proposed at a contained price. It uses dynamic transducers with a diaphragm specially designed by the brand for a transparent and precise sound reproduction.
Like other IEMs of the brand, the MS1 is equipped with the brand new 10.2mm polymer bio-membrane dynamic driver, capable of providing an extended frequency response from 20Hz to 40kHz. In addition, the dual magnetic circuit and dual acoustic chamber allow for a beautiful soundstage and high accuracy.
The body of the MS1 is made of high-density German Makrolon resin. The very structure of the IEMs, based on a large amount of ergonomic data, ensures a comfortable fit even during long listening sessions.
Practical, the cable of the MS1 integrates controls as well as a microphone. It is thus possible to control the playback of music but also to answer calls, without having to take your smartphone out of your pocket.
To promote accurate sound reproduction, the MS1's sound tube is made of an aluminum alloy with gold plating, allowing every detail to be reproduced in perfect clarity.
The supplied cable consists of four silver-plated OFC copper conductors, ensuring optimal transmission of the audio signal.
The cable is also interchangeable, plugging into the headphones on a 0.78mm 2-pin connector. It is thus possible to simply replace it with another model if needed.
Product type | In-Ear Monitors (IEM) |
Diaphragm | Polymer |
Drivers | Dynamic drivers Ø10.2mm |
Housing material | Makrolon Resin Gold-plated aluminum alloy acoustic tube |
Integrated controls and microphone | |
Frequency response | 20Hz - 40kHz |
Sensitivity | 112dB |
Impedance | 20Ω |
Cable conductors | 4x Silver plated OFC Copper conductors |
Cable length | 1.2m |
IEM connectors | 0.78mm 2 pins Gold plated |
Cable input connector | Gold palted Jack 3.5mm |
Power handling | 10mW |
Weight | ≈ 6g |
Package | Hidizs MS1 1x Single-ended cable with microphone 1x Transport bag 2x Eartips pairs |
Color | Black |
Impedance (Ω) | 20 |
Efficiency / Sensitivity (dB) | 112.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
