Hidizs MP143 Salt in-ear monitors are IEMs with a 14.3mm planar magnetic diaphragm for rich, natural and detailed sound reproduction. Their architecture is based on balanced magnet arrays for greater precision of movement and low THD. In addition, their 103dB sensitivity and 17 ohm impedance make them easy to drive, whether for use with a smartphone, portable DAC or Hi-Fi headphone amplifier.
These Hidizs MP143 Salt headphones are based on “FAST 2” technology, a magnetic planar diaphragm no less than 14.4mm in diameter. The advantage of using the latter is that it offers an extended dynamic range and, consequently, a richer, more detailed sound.
The magnet circuit of the MP143 Salt is composed of a structure of 7+7 N52 neodymium magnets. This design ensures low distortion for clear, transparent listening.
The Hidizs brand has applied its experience to the MP143 Salt IEMs to achieve a frequency response as close as possible to the H-2019 reference. The result is an extended frequency response in the treble range 20Hz-40kHz, in line with Hi-RES standards. Added to this are three filtering tips to adapt the sound to the user's taste or the type of music being played.
The Hidizs MP143 Salt features a detachable CIEM cable with OFC copper conductors. One end features two 0.78mm CIEM connectors and a balanced 4.4mm jack termination.
The cable supplied here is 4.4mm jack terminated. The Hidizs MP143 Salt version with a 3.5mm jack termination cable is available here.
Product type | In-ear monitors (IEM) |
Diaphragm | Planar magnetic |
Diaphragm diameter | Ø14.3mm |
Magnetic circuit | 7+7 N52 |
Impedance | 17 Ohm |
Sensitivity | 103dB |
Frequency response | 20Hz-40kHz |
THD | < 0.05% |
Cabl especification | |
Length | 1.2m |
Conductor material | OFC copper |
IEM Connectors | 2x CIEM 0.78mm |
Terminason | Balanced Jack 4.4mm |
Color | Black |
Weight | 8g/monitors |
Package | 1x Hidizs MP143 Salt 1x CIEM 0.78mm detachable cable to balanced 4.4mm jack 6x Pairs of in-ear tips 3x Pairs of filter tips 1x Storage pouch |
Color |
Impedance (Ω) |
Efficiency / Sensitivity (dB) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
Wireless |
Cable termination |
Headphone / Earphone connector |
Phone call feature |
Noise reduction |
