HIDIZS MP145 IEM In-ear Monitor IEM Blue
The HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7 N52H magnets. In terms of measurement, their high sensitivity of 104dB and low impedance of 30 Ohm enable them to be easily driven by a wide range of devices, such as your telephone or a portable DAC.
Reference : 18998
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 25-04-2025.
HIDIZS MP145 In-ear Monitor IEM Planar Magnetic 30 Ohm 104dB 20Hz-40Hz BlueHidizs MP145 picture
The HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7 N52H magnets. In terms of measurement, their high sensitivity of 104dB and low impedance of 30 Ohm enable them to be easily driven by a wide range of devices, such as your telephone or a portable DAC. The planar magnetic driver enables MP145 IEMs to maintain an ultra-low distortion rate of less than 0.05%, and provides a wide frequency response from 20Hz-40KHz. In addition to these features, the HIDIZS MP145 comes with 3 filter tips and 3 available tuning modes, for a total of 9 tone-setting possibilities to suit your preferences or the style of music you're listening to. A high-quality audiophile cable 2x 0.78mm to 3.5mm jack termination with silver-plated OFC copper conductor completes the package.
Les points forts des IEM Hidizs MP145
HIDIZS MP145: 14.5mm planar magnetic driver
The HIDIZS MP145's ultra-wide planar magnetic driver delivers an immersive, dynamic soundstage and a wide frequency response from 20Hz to 40KHz. Compared with a dynamic driver or a balanced armature driver, it delivers better transient response and a wider, more detailed high-frequency spectrum.
Vue éclatée des Hidizs MP145
Photo du circuit magnétique des IEM Hidizs MP145
HIDIZS MP145: A balanced magnetic circuit
The magnetic circuit of the Hidizs MP145 is totally balanced, with a precise arrangement of 7+7 N52H magnets in each earphone. This design reduces harmonic distortion, improves magnetic circuit efficiency and delivers maximum magnetic flux for clear, brilliant sound quality.
HIDIZS MP145: 9 listening styles available
Thanks to 3 filter tips designed to highlight vocals, balanced sound or bass, and 3 available listening modes: high-frequency, balanced and low-frequency, the MP145 adapts to your listening preferences and the musical style being played.
Photo des embouts de filtre des HIDIZS MP145
Niveau de confort des HIDIZS MP145
HIDIZS MP145: A design for efficient heat dissipation and a high level of comfort
The MP145's whale-tail-inspired shell design features 2 ventilation holes to optimize the flow of internal air. In addition, their shape and light weight offer a good fit on your ear and a feeling of comfort even over long listening sessions.
HIDIZS MP145: frequency response aligned with the 2019 Harmann curve
The frequency response curve of the HIDIZS MP145 is aligned with the Harmann 2019 curve following calibration by the brand. This gives the MP145s a high level of detail in both low and high frequencies.
Courbe de réponse en fréquence des HIDIZS MP145
Câble des IEM HIDIZS MP145
HIDIZS MP145: an audiophile cable
The cable supplied with the HIDIZS MP145 is a 1.2 m cable with a silver-plated OFC copper conductor for optimum conductivity. This cable features two 0.78mm CIEM connectors and a 3.5mm jack cable termination compatible with the vast majority of devices on the market.
Product typeIn-ear monitors
Driver typePlanar magnetic
Driver diameterØ14.5mm
Body materialAluminium
Frequency response20Hz-40KHz
Sensitivity104dB
Impedance30 Ohm
Distorsion< 0.05%
Cable typeDetachable 2x CIEM 0.78mm to 3.5mm jack termination
Cable length1.2m
Cable conductor materialSilver-plated OFC copper
Jack connector contact materialGold-plated pure copper
Filters3 tips + 3 setting modes
Weight19g
ColorBlue
Package1x IEM HIDIZS MP145
1x CIEM 0.78mm to 3.5mm jack cable
3x Filter tips
9x In-ear tips
1x Storage pouch
ColorBlue
Impedance (Ω)30
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
HIDIZS MP145 In-Ear Monitor IEM Planar Magnetic 30 Ohm 104dB 20Hz-40Hz Blue
The HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7...
