With the MS3, Hidizs offers quality in-ear earphones based on a combination of a Ø10.2mm dynamic driver and a Balanced Armature tweeter for deep, dynamic bass and perfectly defined highs. Furthermore, these earphones come with 3 filters, each offering a different frequency response.
The MS3 in-ear earphones use a dynamic driver with a Ø10.2 mm bio-nanofiber membrane with dual magnetic circuit and double cavity, developed directly by Hidizs.
This type of driver has a stronger induction than conventional drivers. Under the action of a stronger magnetic induction, the diaphragm can produce more acoustic energy, thus improving the driver's transient performance and energy conversion efficiency, as well as making the diaphragm's response more stable.
Dual cavities are based on the design of the magnetic circuits to form two relatively independent cavities, bringing numerous advantages such as deeper, more dynamic bass and clearer rendering of vocals and, more generally, mid-range frequencies.
The MS3 uses Knowles' SWFK-31736 balanced armature composite tweeter for high and very high frequencies. The result is surgically precise, crystal-clear treble.
The MS3 body is made of aluminum alloy, sculpted by five-axis CNC to match the shape of the human auricle. Its surface has been anodized and oxidized to pure black, for an aesthetic finish that's both classy and sober.
Hidizs MS3s offer the option of applying one of three filters. These different sound signatures make it possible to adapt to different musical genres and listening styles.
Balanced - Rose Gold: Excellent performance across all frequency bands, with enhanced musicality. Particularly suitable for folk and pop.
Treble - Quiet Silver: High-frequency enhancement for greater precision. Suitable for classical music.
Bass - Charm Red: Accentuates low frequencies, for furthermore impactful bass. Ideal for rock.
To get the best out of the different types of drivers used, Hidizs has redesigned the crossover of its earphones to use tantalum capacitors to control it. Tantalum capacitors have a higher frequency response and a lower ESR (Equivalent Series Resistance), resulting in a clearer, more precise final sound.
The MS3 features a detachable 192-strand 0.08mm OFC copper cable, with a total thickness of 6mm and a length of 1.2m. The connectors are gold-plated for total resistance to oxidation. Furthermore, the CIEM 2-pin 0.78mm connectors feature the shark-fin design of the MS5s, providing a more stable connection that's harder to twist.
This top-of-the-range pair of earphones is Hi-Res certified. This is a guarantee of quality sound reproduction.
Product type | In-ear monitors |
Speakers | 1x Ø10.2 mm dynamic driver 1x Balanced Armature tweeter |
Filters | 3 filters: Balanced - Rose Gold Treble - Quiet Silver Bass - Charm Red |
Impedance | 18Ω |
Frequency response | 20Hz-40kHz |
Sensitivity | 112dB |
Cable length | 1.2m |
Cable conductor | OFC Copper |
Earphones connector | 2 pins 0.78mm CIEM, gold plated |
Connecteur du câble | Jack 3.5mm, gold plated |
Matériau corps | Aluminum alloy, CNC machined |
Weight | ~15g |
Color | Black |
Package | 1x Hidizs MS3 1x Jack 3.5mm to CIEM 0.78mm 2-pin cable 1x Carrying bag 3x Filter pairs 9x Pairs of ear tips |
Color | Black |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 112.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
