HIDIZS MS3 In-Ear Monitors Jack 4.4mm
With the MS3, Hidizs offers quality in-ear earphones based on a combination of a Ø10.2 mm dynamic driver and a balanced armature tweeter for deep, dynamic bass and perfectly defined highs. Furthermore, these earphones come with 3 filters, each offering a different frequency response.
Reference : 20420
109,00 €tax incl.
90,83 € tax excl.
Hidizs MS3 In-Ear Monitors IEM Jack 4.4mm Dynamic Balanced Armature 18Ω 112dB 20Hz-40kHz
Hidizs MS3 : Front view
With the MS3, Hidizs offers quality in-ear earphones based on a combination of a Ø10.2mm dynamic driver and a Balanced Armature tweeter for deep, dynamic bass and perfectly defined highs. Furthermore, these earphones come with 3 filters, each offering a different frequency response.
Hidizs MS3 : product overview
Hidizs MS3: Dynamic driver with dual magnetic circuit
The MS3 in-ear earphones use a dynamic driver with a Ø10.2mm bio-nanofiber membrane with dual magnetic circuit and double cavity, developed directly by Hidizs.
This type of driver has a stronger induction than conventional drivers. Under the action of a stronger magnetic induction, the diaphragm can produce more acoustic energy, thus improving the driver's transient performance and energy conversion efficiency, as well as making the diaphragm's response more stable.
Dual cavities are based on the design of the magnetic circuits to form two relatively independent cavities, bringing numerous advantages such as deeper, more dynamic bass and clearer rendering of vocals and, more generally, mid-range frequencies.
Hidizs MS3 : dynamic driver
Hidizs MS3 :balanced armature driver
Hidizs MS3: Balanced-armature tweeter
The MS3 uses Knowles' SWFK-31736 balanced armature composite tweeter for high and very high frequencies. The result is surgically precise, crystal-clear treble.
Hidizs MS3: CNC-sculpted aluminum body
The MS3 body is made of aluminum alloy, sculpted by five-axis CNC to match the shape of the human auricle. Its surface has been anodized and oxidized to pure black, for an aesthetic finish that's both classy and sober.
Hidizs MS3 : CNC aluminum body
Hidizs MS3: Customize your listening
Hidizs MS3s offer the option of applying one of three filters. These different sound signatures make it possible to adapt to different musical genres and listening styles.
Balanced - Rose Gold: Excellent performance across all frequency bands, with enhanced musicality. Particularly suitable for folk and pop.
Treble - Quiet Silver: High-frequency enhancement for greater precision. Suitable for classical music.
Bass - Charm Red: Accentuates low frequencies, for furthermore impactful bass. Ideal for rock.
Hidizs MS3 :Available filters
Hidizs MS3: Frequency response
To get the best out of the different types of drivers used, Hidizs has redesigned the crossover of its earphones to use tantalum capacitors to control it. Tantalum capacitors have a higher frequency response and a lower ESR (Equivalent Series Resistance), resulting in a clearer, more precise final sound.
Hidizs MS3 : Frequency response
Hidizs MS3: OFC copper cable
The MS3 features a detachable 192-strand 0.08mm OFC copper cable, with a total thickness of 6mm and a length of 1.2m. The connectors are gold-plated for total resistance to oxidation. Furthermore, the CIEM 2-pin 0.78mm connectors feature the shark-fin design of the MS5s, providing a more stable connection that's harder to twist.
Hidizs MS3 : 2-pin 0.78mm CIEM connectors
Hidizs MS3 : Hi-res Certification
Hidizs MS3 : Hi-Res Certification
This top-of-the-range pair of earphones is Hi-Res certified. This is a guarantee of quality sound reproduction.
Product typeIn-ear monitors (IEM)
Speakers1x Ø10.2mm dynamic driver
1x Balanced armature tweeter
Filters3 filters:
Bass - Charm Red
Impedance18Ω
Frequency response20Hz-40kHz
Sensitivity112dB
Cable length1.2m
Cable conductorOFC Copper
Earphones connector2 pins 0.78mm CIEM, gold plated
Connecteur du câbleJack 4.4mm, gold plated
Matériau corpsAluminum alloy, CNC machined
Weight~15g
Package1x Hidizs MS3
1x Jack 4.4mm to CIEM 0.78mm 2-pin cable
1x Carrying bag
3x Filter pairs
9x Pairs of ear tips
Impedance (Ω)18
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
HIDIZS MS3 In-Ear Monitors IEM Jack 4.4mm Dynamic Balanced Armature 18 Ohm 112dB 20Hz-40kHz
With the MS3, Hidizs offers quality in-ear earphones based on a combination of a Ø10.2 mm dynamic driver and a balanced armature tweeter...
