HIDIZS MS5 In-Ear Monitors IEM 5.3 Ohm 104dB 20Hz-40kHz Black
Hidizs unveils with the MS5 a model of in-ear monitors (IEM) of very high quality, integrating no less than four drivers. These are the result of a long period of R&D of the brand, each element being optimized in the smallest details to provide a sound reproduction as rich as precise and immersive.
By buying this product you get 38 loyalty points
Reference : 17781
389,00 €tax incl.
324,17 € tax excl.
Shipping date: 24-04-2025.
Hidizs MS5
In Ears Monitors IEM 5.3Ω 104dB 20Hz-40kHz Black
HIDIZS MS5 Ecouteurs Intra-Auriculaires IEM 5.3 Ohm 104dB 20Hz-40kHz Noir
Four BA speakers
The Hidizs MS5 combines four Balanced Armature drivers, specially developed and optimized over many years by the brand's engineers, to deliver incredible sonic performance. Each earphone features an E50DT driver for high-frequency reproduction, providing accurate and detailed sound, a 2389 midrange driver for presence and texture, and two 17A003 woofers to deliver deep, rich bass.
New liquid silicone dynamic driver
The MS5 features a new 10mm dynamic driver. It is composed of a kevlar body with a thickness of only 0.03mm and is coated with a thin layer of 0.45mm silicone. This allows the driver to keep a very good elasticity and therefore a very high reactivity.
Choose your sound
The Hidizs MS5 IEMs offer the ability to apply one of three available filters. These different sound signatures allow you to adapt to different musical genres and listening styles.
Balanced: Excellent performance across all frequency bands, enhanced musicality. Especially suitable for folk and pop music.
Treble: High frequency emphasis for increased accuracy. Suitable for classical music.
Bass: Accentuation of low frequencies, for a more impactful bass. Ideal for rock music.
Elegant Design
The MS5s have an elegant and luxurious design, with a meticulously CNC machined aluminum alloy body and rose gold frame. They adopt a monoblock aluminum alloy design allowing them to be very lightweight.
Perfect comfort
The earphones connector has an angled design to better adapt to the shape of the ear. This makes the MS5 very comfortable to wear, even for long listening sessions.
High quality cable
The MS5 cable also benefits from a high quality design.  It consists of a total of 504 silver plated 6N copper wires. These wires are then braided into 8 strands. The cable is thus solid and allows an increased conductivity for a pure and delicate sound.  The 3.5mm jack plug is made of gold plated copper
2 pin 0.78mm connector
The MS5 cable is also detachable, each earphone having a 2 pins 0.78mm connector. It is thus possible to easily replace the original cable.
Leatherette case
The Hidizs MS5 comes with a high quality PU leatherette case.  Resistant and waterproof it is the perfect ally to carry and protect your earphones.
Hi-Res certification
This pair of high-end headphones has the Hi-Res certification, a guarantee of quality sound reproduction.
Product typeIn-ear monitors
Speakers4BA + 1DD:
1* High frequencies driver
1* Midrange driver
2* Low frequencies drivers
1* 10mm liquid silicone and kevlar dynamic driver
Filters3 filters:
Balanced
Treble
Bass
Crossover3 way
Impedance5.3Ω @ 1kHz
Frequency response20Hz - 40kHz
Sensitivity104 dB
Cable length1.2m
Cable conductorSilver plated OFC copper
Earphones connector2 pins 0.78mm CIEM gold plated
Cable connectorJack 3.5mm gold plated
Body materialAluminum alloy, CNC machined
Weight~13.6g
PackageHidizs MS5
1* 3.5mm jack cable
1* Leatherette carrying case
9* Earpieces
Impedance (Ω)5.3
Efficiency / Sensitivity (dB)104.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
Hidizs unveils with the MS5 a model of in-ear monitors (IEM) of very high quality, integrating no less than four drivers. These are the result of a...
