HIFIMAN RE-2000 "Audiophile" In-Ear Monitor 24k Gold Edition
10%
Reduced price!
Reference : 12034
Limited special offer
1 990,00 €tax incl.
-10%
1 791,00 €tax incl.
1 492,50 € tax excl.
Shipping date: 15-04-2025.
HIFIMAN RE2000
In-Ear Headphones
Hifiman RE2000
24k Gold Edition
If the brass used for the body of this EMI greatly improves its acoustics, it is otherwise for audio output.
Thus, the RE200 24k Gold Edition uses an electrolytic plating giving this brilliant shine.
Topological Driver
Hifiman uses advanced technology to improve the sound reproduction of RE2000. With its "Topology Driver" Hifiman greatly improves the control and precision of its headphones, resulting in great clarity, a high level of detail and sharp nuances, while maintaining a coherent sound.
Hifiman RE2000
Advanced Technology
The topological driver refers to the nano-particle-based plating of the diaphragm, applied to reproduce geometric patterns. By varying this pattern the spectrum can be manipulated pto offer an ever better sound.
The idea behind this technology is inspired by the thesis of Dr. Fang Bian's Ph.D., arguing that "different nano-materials have different structures and each of these materials has its own properties." Thus, by carefully controlling the structure of the surface of the diaphragm, you obtain acoustic results that were previously unattainable. Moreover, the distortion is greatly reduced and the dynamics improved.
Hifiman RE2000
Many tests to offer you the highest quality audio
After the creation of numerous prototypes and the constant realization of user tests, HifiMan has worked to offer you exceptional audio quality.
Hifiman RE2000
A structure for design and comfort
With these RE2000, Hifiman redefined the structure of its IEM, offering an industrial design combining design and comfort. Offering a size designed for comfort and optimized insulation, these headphones push the listening experience to the highest. What's more, the cable is detachable and changeable, to fit all your envies.
Hifiman RE2000
Frequency Response20Hz - 20kHz
impedance60 Ohms
<sensitivity/ Td>103dB
Type of diaphragmtopological
connector3.5mm Jack
Driver TypeDynamic 9.2mm
PlatingGold 24k
Cable materialCopper plated Silver
Headphones13.8g
Weight cable23g
Impedance (Ω)60
Efficiency / Sensitivity (dB)103.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorMMCX
Phone call featureNo
Noise reductionNo
