With the Svanar Wireless Jr, HiFiMAN offers wireless earphones where no compromises have been made. Each earphone is built around a DSP and a class AB symmetrical amplification stage, so you can enjoy the distinctive touch of AB amplification anywhere, combined with the convenience of a Bluetooth connection.
To ensure the best possible sound reproduction, Hifiman has equipped the Svanar Jr with a class AB symmetrical amplifier with an output power of 10mW at 32Ω and a harmonic distortion rate of 0.019%. Furthermore, this amplification is accompanied by a DSP to optimise your signal for optimum reproduction.
The ‘topological diaphragm’ refers to a diaphragm whose surface is coated with a special nanoparticle-based coating. The result is a more natural and detailed sound than that generally obtained with wireless earphones. The idea behind the new topological membrane was inspired by Dr Fang Bian's doctoral thesis, which states that ‘different nanomaterials have different structures and each of these materials has its own properties’. Therefore, by carefully controlling the surface structure of the diaphragm, we can achieve different results that are superior in terms of acoustic performance to a degree hitherto unattainable.
To ensure lossless transmission of information, Svanar Jr earphones support the Bluetooth LDAC transmission protocol, giving you a signal of identical quality to the original.
To immerse you completely in your tracks, the Syanar Jr earphones feature an active noise cancellation system. The principle is based on ambient noise being picked up by microphones. A signal with the opposite phase to the noise picked up is then generated and integrated into the audio signal, neutralising external noise.
Product type | Wireless In-Ear Monitor IEM |
Frequency response | 10Hz - 35kHz |
Bluetooth version | 5.2 |
Noise cancellation | -35dB |
Protection class | IPX5 |
Bluetooth operating distance | 15m (barrier-free open environment) |
Total harmonic distortion (THD) | 0.019% |
Output level | 10mW @ 32Ω Max : 50mW @ 32Ω |
Autonomy | |
Battery life of earphone | 8h |
Battery life of charging case | 32h |
Weight | 100g |
Color | White |
Package | 1x Hifiman Svanar Wireless Jr 1x Charging case 8x Silicone Eartips (S, M and L) |
Color | White |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 35000 |
Wireless | Yes |
Cable termination | Wireless |
Headphone / Earphone connector | Wireless |
Built-in microphone | No |
